Author Topic: firewall pad question  (Read 2816 times)
Offline original68
« on: October 08, 2013, 12:30:11 PM »
i need to replace the original firewall pad for my 68 a/c car.  i dont want to use a repro.  i have an original 68 non a/c pad available locally.  can this one be easily  modified by removing material for the heater box.  or would it require more mods.  is the 67 a/c firewall pd the same as a 68 a/c pad. thanks much for any info
Re: firewall pad question
« Reply #1 on: October 08, 2013, 01:56:10 PM »
I would go an look at the pad. I thought that they were perforated so that they could be used with or without A/C.
« Reply #2 on: October 08, 2013, 02:04:09 PM »
+1 one pad fit all . Heater delete ,heater only and A/C. Areas perforated to take out depending on application.
Offline original68
« Reply #3 on: October 08, 2013, 03:04:07 PM »
is the 1968 cougar fire wall pad the same as the 68 mustang
« Reply #4 on: October 08, 2013, 03:47:44 PM »
Mustangs from in front of the seat risers forward are the same under the skin as a Cougar. They share all of the same parts, except for anything 6 cylinder related. Coupe windshields are the same as coupe Cougars too.
The wiring, instrumentation, and dash parts and pads are different.
Offline original68
« Reply #5 on: October 08, 2013, 04:28:45 PM »
Scott thanks for all your help
« Reply #6 on: October 08, 2013, 09:59:53 PM »
If you go for an original replacement be aware that the style (texture) differed depending on where the car was built on 65-68's in most cases ;)
Either the ones with the raised dots in a pattern or the heavy texture (no pattern) that looks like undercoating
Offline TLea
« Reply #7 on: October 10, 2013, 08:42:28 AM »
or the one with texture and dots behind it  ;D
