Author Topic: A/C on 200ci mustang  (Read 1985 times)
Offline colo59
« on: October 03, 2013, 04:08:26 AM »
Hello ,
I have a 200ci 66 mustang with power steering and A/C.
My A/C don't work and I would rebuilt it but I have a little problem , I don't know how can put belts .
My P/S have 1 groove , A/C have 1 groove , water pump have 2 grooves and engine have 2 grooves .
I serch on the web , I find this drawing on Classic Air website
The A/C have 2 grooves .
Do you know another mounting ?
Thanks for your help .
Fred
Offline C5ZZ
Re: A/C on 200ci mustang
« Reply #1 on: October 03, 2013, 11:29:13 PM »
The picture in the illustration "A/C with P/S" is the correct routing,
you will need a two groove A/C clutch pulley, a little tough to find.
Here are some pictures that might help you.
MCA # 00945
Rangoon Red/Red Interior
Offline colo59
« Reply #2 on: October 04, 2013, 11:05:55 AM »
Thanks for pictures .
Offline suskeenwiske
  • 214-347-3628
« Reply #3 on: October 09, 2013, 12:48:47 AM »
I'm in the process of restoring my '65 which also has A/C and PS. Though not yet restored I've attached a couple of photos of what the 2-groove clutch looks like; it may help you to find the correct clutch. Classic Air has a catalog and price sheet that you can download, you may be able to purchase the clutch from them or other Mustang suppliers.
Ray
1965 Dearborn Coupe
6 Cylinder, AT, PB, PS, AC
Est. Build 23A
Offline C5ZZ
« Reply #4 on: October 09, 2013, 10:16:41 AM »
There were two different style clutches used, one used brushes
and the other used a coil, they look different in the front also
but will both work as long as they have two grooves for the belts.
MCA # 00945
