Author Topic: 67/8 Upper ball joints  (Read 2176 times)
Offline CT428CJ
« on: October 03, 2013, 12:49:01 AM »
Does anyone have pictures of assembly line installed upper ball joints?
Offline Dudley
Re: 67/8 Upper ball joints
« Reply #1 on: October 03, 2013, 08:20:17 AM »
SJ june  68 build  289-2V w/AC/PS pictures below..........
Different lighting was used in the first picture which gives off a yellowish tint, other two used clear light.
First and second pic's are of the driver's side,  and third is of the passenger side.
If it helps.
« Last Edit: October 03, 2013, 11:56:28 AM by Dudley »
Offline Dudley
« Reply #2 on: October 03, 2013, 09:21:05 AM »
General question about posts. When I login under my name I see the pictures I posted in my reply to this thread.  However, when I enter the website without logging in , instead as a guest, the pictures do not appear. Is there something that I have not done properly, or am I not accustomed to viewing as a guest?
« Reply #3 on: October 03, 2013, 10:46:13 PM »
Don't think I've got any pretty nice looking  original ones that have not bee cleaned and such - Is there  a particular detail (waffle pattern, color/tone of rivets, boot style...) that your looking for?   Might have something in that case ;)
Offline CT428CJ
« Reply #4 on: October 03, 2013, 11:43:36 PM »
Jeff,
 I am looking for detail on the body & boots.
Offline 69bossnut
    • DSD Restorations LLC
« Reply #5 on: October 04, 2013, 12:59:42 AM »
Chris,
Here is a pic of a C7 upper ball joint. Hopefully this will help.
DAVID DAVIS
DSD RESTORATIONS LLC
5075 E. COUNTY RD. 126
BLYTHEVILLE, AR. 72315
870-780-4999
dsdresto@gmail.com
www.dsdrestoration.com
Offline CT428CJ
« Reply #6 on: October 05, 2013, 01:06:53 AM »
So the assembly line parts are the same as the replacement parts?
« Reply #7 on: October 05, 2013, 02:39:36 AM »
Yes and no. Typically the service parts evolved from like assembly line as in early service parts to later versions that were not. typically the boot and it's markings retainer ring  rivits etc. are the determining factor. I think 69bossnut has some real new OLD stock service parts that are like assemblyline.
