Author Topic: correct fastener finish  (Read 4276 times)
Offline original68
« on: September 30, 2013, 09:34:38 PM »
hello what is the correct finish for the bolts that attach the steering box to the frame.  power steering ram bracket to frame and idler arm to frame. on a 1968 san jose car. mine are corroded and cant make out the correct finish. i was hoping for zinc phosphate as i bought the liquid to replicate the finish. if they are the natural steel color is the best option to spray paint them.  i was hoping to keep the original fasteners and restore them..  thanks for all the help
Re: correct fastener finish
« Reply #1 on: September 30, 2013, 10:09:12 PM »
Zinc phosphate they are. ;D
Offline original68
« Reply #2 on: September 30, 2013, 10:37:47 PM »
Thanks much
« Reply #3 on: September 30, 2013, 11:12:13 PM »
Over the phosphate they were dyed (as a safety item to catch the workers eye and attention) red.
I use machinist dye for the purpose
Your idler arm and nuts are treated and finished the same way ;)
The look of the finished part is dependent on the plating or coating applied to the piece before the dye
Offline original68
« Reply #4 on: September 30, 2013, 11:54:25 PM »
thanks jeff
Offline preaction
« Reply #5 on: October 02, 2022, 11:40:38 PM »
Jeff, were the whole bolts for the steering box dyed red ? Not safety items but what should the D washer and lock washer be P+O ?
« Reply #6 on: October 05, 2022, 12:13:01 AM »
On a 68 I've seen the complete bolt dyed - Hidden/protected area inside the frame rail with the dye still present. The washer and lock washer would just be the dark finish such as P & O  without the dye
