Author Topic: 69 Antenna  (Read 1493 times)
69 Antenna
« on: September 28, 2013, 01:23:02 PM »
     Is it possible to identify this antenna by the C9AA-18A927-A ink stamped on the down side of the bezel ? If so; assembly line, service department or after market ?  Thanks,  Brian
Offline PerkinsRestoration
Re: 69 Antenna
« Reply #1 on: September 28, 2013, 08:23:25 PM »
No, the bezel fits other applications also. Is it correct for Mustang, yes. Your antenna is also correct as it has round mast and teardrop black insulator.
Re: 69 Antenna
« Reply #2 on: September 28, 2013, 10:02:25 PM »
     Thanks for the reply and information.  Brian
Re: 69 Antenna
« Reply #3 on: September 29, 2013, 06:53:41 PM »
Brian the best way to check is looking under the cast base for fomoco 7-292 for 69-70 assembly line antenna & c9za # on bottom of rubber mount as cougar is c9wa. Many antennas look the same but the cast id # & rubber molded in # have to be correct for antenna to be mounted concours correct.
Re: 69 Antenna
« Reply #4 on: September 30, 2013, 11:45:00 AM »
     Thanks for the tip.  It seems that Ford took some extraordinary steps to insure that the antenna would be securely attached to the car.  I am going to leave well enough alone and not try to get a peek at the down side of either part.  I think I understand the " mounted concourse correct " portion of your statement.   Brian
