Author Topic: 1968 Shelby GT500 KR Steering and Suspension Detailing  (Read 5298 times)
Offline dwdshelby
« on: September 24, 2013, 09:44:03 PM »
Hi, thanks again for the help on the rear end and unibody.
I am now working on the front suspension and steering. I have a fair bit of information on the correct equipment and cosmetics for the front suspension for the KR.
Again, it is a June 3, 1968 build (Metuchen) and it is a convertible.
I have not found as much info on the steering components so I wanted to check with the experts on proper detailing.
* Sway bar - Chassis Black (?);
* Sway bar bushing holders - ?
* Sway bar end links - natural steel un-painted - ?
* Steering box, pitman arm, centre link, inner and out tie rods - natural cast finish (?);
* Steering column (behind the dash through fire wall) - ?
* Tie rod adjustment sleeves - natural steel - ?
* Power steering - not sure what the right colour is for the control valve and power cylinder - ?
* Power steering reservoir and pulley - blue and black respectively - ?
Again, thanks so much for your help.
Best
Dwdshelby
Re: 1968 Shelby GT500 KR Steering and Suspension Detailing
« Reply #1 on: September 24, 2013, 10:02:41 PM »
* Sway bar - Chassis Black (?); - Semigloss black
* Sway bar bushing holders - Natural untreated sttel
* Sway bar end links - natural steel un-painted - believe (Tim will add in if needed) bolt and spacer plated cad/zinc
Steering box (check for threads) is a combination of cast main body, bright machined surfaces, zinc/cad plated end plug, natural steel cover, dark hardened cover bolts, bright machined shafts and spines
Center link and main tie rod bodies - darker heat treated forged steel. Tie rods have brighter machined caps, exposed shafts bight machine natural steel
* Steering column (behind the dash through fire wall) - Natural steel with natural steel attachment plate to rag joint. Blued weld and areas near weld
* Tie rod adjustment sleeves - natural steel - Yes new steel look - not as dark as tie rods
Do another search - a number of pictures and articles
Ram - natural with blued seam running length wise and ends where the tube was attached to the ends
Control valve - combination of fresh cast iron, cast aluminum and new steel spacer. Cast iron section has bright fresh machined surfaces
* Power steering reservoir and pulley - blue and black respectively - Depends on which pump you have (who made the pump)  Che3ck the tag and do a search. Tag = color threads have been posted
Sure I missed a couple of things but that should get things going ;)
« Reply #2 on: December 23, 2020, 04:51:58 PM »
Subject came up again in a round about way (discussing 67's) so wanted to post some pictures here as references. From age we can expect the colors and tones to change some what but its what we have to work with. Also we have to consider out flash or lighting wash as well as digital camera settings
Hope this helps others
Offline Coralsnake
« Reply #3 on: December 23, 2020, 07:28:05 PM »
The steering column outer tube will be the interior color either black charcoal or saddle
Offline preaction
« Reply #4 on: December 23, 2020, 10:30:37 PM »
Jeff, Im guessing your pics are from an unrestored example of late 68 car ?
« Reply #5 on: December 24, 2020, 04:11:08 PM »
May 68 example
