Author Topic: 66 SJ Radiator  (Read 2791 times)
66 SJ Radiator
« on: September 22, 2013, 10:52:30 PM »
     I have a radiator that came with a San Jose, C code, 66 hardtop.  I had it re cored to a three row.  After a while the top solder seam let go so I put it in storage and forgot about it.  The only stampings I can see are on the tank top.  They are W-MO and below that 12 65.  The fill spout is off-set to the LEFT, hose openings are located on the RIGHT and it has the auto trans fittings/tank.  Ideas on the origins or why it is not marked with a C4ZE ?  Thanks,  Brian
« Last Edit: August 01, 2023, 06:09:45 PM by J_Speegle »
Re: 66 SJ Radiator
« Reply #1 on: September 24, 2013, 09:08:18 PM »
Sorry I don't see anything out of the nor - here is just one of the examples I have
By the time this radiator was made the producer/contractor had started labeling the radiators with a soldered  on tag rather than the imprinted top tank. Likely this gave them more flexibility and saved them money
« Last Edit: August 01, 2023, 06:09:52 PM by J_Speegle »
Re: 66 SJ Radiator
« Reply #2 on: September 24, 2013, 10:43:01 PM »
     Looks like photo example you posted leaked in the same place.  Interesting about the brazed tag by late 65.  The scheduled build date for this car was 12-15-65.    Thanks,  Brian
« Last Edit: August 01, 2023, 06:09:58 PM by J_Speegle »
Offline Brant
Re: 66 SJ Radiator
« Reply #3 on: September 25, 2013, 10:04:17 AM »
Here is an example with the separate tag, rather than the "stamped in tank" C4ZE number.
I've seen the separate tag on SJ radiators dated as early as 9 65.
« Last Edit: August 01, 2023, 06:10:06 PM by J_Speegle »
Re: 66 SJ Radiator
« Reply #4 on: September 25, 2013, 01:46:32 PM »
     Thanks for the picture Brant.  I' am learning some new stuff here about these radiators.  I honestly never really noticed the brazed on tag or its location.
« Last Edit: August 01, 2023, 06:10:18 PM by J_Speegle »
Re: 65-66 Radiator
« Reply #5 on: September 25, 2013, 10:36:11 PM »
Might not be there - as mentioned allot fo the time the rebuilder didn't re attach them :(
Re: 66 SJ Radiator
« Reply #6 on: September 25, 2013, 11:14:09 PM »
     Thanks Jeff.  I already figured when the radiator shop torched the shoulder clamps, for the new core, there went the tag.  Don't have to worry about that sort of thing any more.  All the local radiator shops have closed, most of the machine shops as well as all the chrome shops.  Brian
« Last Edit: August 01, 2023, 06:10:26 PM by J_Speegle »
Re: 66 SJ Radiator
« Reply #7 on: September 26, 2013, 01:10:24 AM »
FYI the metal tag is not "brazed" on but is soldered on which makes them much easier (much easier then brazing) to add to a radiator with one missing. A propane torch ,solder ,flux and the metal tag and you can make your dated radiator historically correct.
« Last Edit: August 01, 2023, 06:10:36 PM by J_Speegle »
Offline s2ms
    • 6S1757 Info
Re: 66 SJ Radiator
« Reply #8 on: September 28, 2013, 03:28:42 PM »
I've found that JB Weld works quite well to easily attach the tag...
Dave
« Last Edit: August 01, 2023, 06:10:43 PM by J_Speegle »
