Author Topic: 66 pony door panel clip w/ foam & clip w/o foam locations?  (Read 977 times)
Offline 7Lscjracer
« on: September 15, 2013, 10:18:11 PM »
For a set of 66 pony door panels, where are the 6 clips with foam and the 8 clips without located on each panel thanks?
Bought May '81, sold Sept '20
Re: 66 pony door panel clip w/ foam & clip w/o foam locations?
« Reply #1 on: September 16, 2013, 01:08:38 AM »
The 66 Interior Assembly Manual calls out 7 (note quantity change) without foam (380552-S3) on the top and 6 with foam (380552-S100) on the bottom. My notes do not show a change in quantity to 8.
Again, I strongly recommend that you invest in a set of the appropriate year assembly manuals.
Offline 7Lscjracer
« Reply #2 on: September 16, 2013, 02:30:07 AM »
Thanks, I'll go 7 without foam on the top and 7 with foam on the bottom then.
The TMI panels have 14 clip holes same as my originals.
I got the 6 and 8 figures from your post on TMI door panels product review, but it does have to go 7 and 7 to split top from bottom.
The 6 on the bottom is likely an early version that failed to secure adequately, so a 7th was added as a running change.
