Author Topic: 65 fastback rear courtesy light wiring  (Read 2776 times)
Offline skinner36
« on: September 15, 2013, 07:33:35 AM »
I have an early Dearborn 65 fastback. The rear passenger courtesy lights are there but there is no wiring harness to connect them to the main loom. Does anyone know a part number of have a picture of the wiring harness required?
Offline C5ZZ
Re: 65 fastback rear courtesy light wiring
« Reply #1 on: September 15, 2013, 11:23:21 AM »
The wiring for the passenger light is basicly a extension cord,
plugs in on the drivers side and runs over to the passenger side,
male connection on one end and female on the other.
I have a used original if you are interested.
MCA # 00945
Rangoon Red/Red Interior
Offline skinner36
« Reply #2 on: September 29, 2013, 01:13:58 AM »
Sorry for the late reply C5ZZ. And thankyou for the offer.
Unfortunately, I live in Australia and don't know how I reimburse a private person.
Offline skinner36
« Reply #3 on: September 29, 2013, 01:16:59 AM »
I am also missing the wire to the driver’s side rear courtesy light. Is this also a separate harness?
« Reply #4 on: September 29, 2013, 08:39:19 AM »
There are two separate harnesses to complete the fastback rear courtesy lights.  The first picks up the signal from the tail-light harness and includes a ground wire for the left (driver side) light.  That harness routes over to the passenger side beneath and below the rear window, ending up in a female bullet plug.  The second harness taps into that bullet plug and provides a plug for the light and a ground lug.
The fastback tail-light harness is unique in that is provides a signal for the rear courtesy lights.
Offline skinner36
« Reply #5 on: September 29, 2013, 06:08:49 PM »
Thankyou Midlife
Offline skinner36
« Reply #6 on: September 30, 2013, 12:04:38 AM »
Midlife,
You say the first one picks up the signal from the tail light harness. Where about would it connect to the tail light harness? I have no free connector by the left (driver side) courtesy light.
The wiring runs from front to back without any breaks until the fuel sender wire seperates from it
« Reply #7 on: September 30, 2013, 08:09:02 AM »
Midlife,
Just forward of that fuel sending wire breakout should be a black/blue wire ending up in a female bullet plug.  If your tail-light harness doesn't have that wire, you can install a separate wire from the main underdash harness (look for a female bullet, two wire black/blue in and around the fuse box) and run it along with the tail-light harness.
Either your black/blue wire has been cut and you can't find it or you have a coupe/fastback tail-light harness.
Offline skinner36
« Reply #8 on: October 04, 2013, 05:26:55 AM »
I just thought I would update you all with what I have found and also what I have decided to do.
I found that the original Fastback harness is supposed to have 6 wires running through it. Mine has only 5 so straight away you know something isn’t right. I then decided that I had two options at this point; the first was to completely replace the whole harness with a reproduction one, or the second was to run a wire from a feed under the dash and wire up the lights myself.
A deciding factor was the fact that my next task is to get the reversing lights working and I want to know that the wiring is correct when I start that job. Also, in the interest of originality, I decided to get a whole new harness. At least this way I know everything should be in order from here on.
