Author Topic: Engine Parts For Sale  (Read 7913 times)
Offline mustangmann
« on: February 17, 2010, 02:02:23 PM »
Hello all;
I have many 289 engine parts for sale:
Blocks:
C4OE-B 5-Bolt 289  with an assembly date of 3K18C (probably out of a "C" code Fairlane, although I removed it from 5F07F100880).
C5AE-E 6-Bolt 289 Casting date of 4M14 assembly date of 4M15T (in the process of disassembly, will know bore size soon).
C5AE-E 6-Bolt 289 STD. Bore 4J4 cast. date and 4J5A assembly date.
C5AE-E 6-Bolt 289 .030 Over. 4H31 cast date and 4J3B assembly date.
C5AE-E 6-Bolt 289 .030 Over. 6L29 cast date and 7A27F assembly date.
C6AE-C 6-Bolt 289 STD. Bore 6A20 cast date and 6B1W assembly date.
260 Short Block, STD. Bore 4B4 assembly date.
I also have a 4L10C and a 7A6M assembly dated 289 engines, but they are not disassembled yet.
Blocks are bare, with caps and are priced at $400 each for STD. Bore blocks, and $250 each for .030 over blocks.  All will be hot tanked and magnafluxed before being sold. I do not want to sell someone a "boat anchor"!
INTAKE MANIFOLDS:
C5OE-A 4bbl. 4G24 date (no road draft tube)
C5OE-C 4bbl. 5B19 date
C5AE-M 4bbl. 5A5 date
C4OE-B 4bbl. 3J27 date
C5OE-A 4bbl. 4F12 date (road draft tube style)
C5AE--D 2bbl. 4G22 date
C4OE-A 2bbl. 4A29 date
C6OE-A 2bbl. 6B1 date
(3) C8ZE-K 4bbl. 7M7, 7M14, 8C1 dates
C9OE-E 4bbl. 351-Windsor 8L4 date
Intakes are priced at $125 each for 4bbl. and $50 each for 2bbl.
WATER PUMPS:
C4OE-8505-A Aluminum
C6OE-A Iron
C3OE-A Aluminum
These are priced at $75 each.
I have many more parts.  Let me know what you need, and I will look.
I am going to be at the Portland Swap Meet, April 9 - 11.  I am also going to travel to the CA Bay Area soon, and can deliver parts to either place.  I can accept Pay Pal.  Photos to interested people.
Thank you!
Ken Mann
p.s. sorry, I tried to turn off the underliner, but I failed!
CT edit: fixed that for you!   8)
« Last Edit: February 17, 2010, 02:10:33 PM by caspian65 »
Offline mustangmann
Re: Engine Parts For Sale
« Reply #1 on: February 17, 2010, 02:59:46 PM »
Thank you Charles!
Offline Raven
« Reply #2 on: April 05, 2010, 09:19:17 AM »
Ken
Looking for a 289 block to match a 67 July 21 production date. Do you have anything available?
Regards
Dino - Sydney/Australia
civicpm@optusnet.com.au
67 A code GTA Convertible San Jose build
67 K code GT Fastback Dearborn build
Offline lcplcruz
« Reply #3 on: May 01, 2010, 07:20:29 PM »
Hi, I sent you an email. I dont know how to PM. (Sorry Newbie)
Offline GM
« Reply #4 on: June 06, 2010, 03:54:51 PM »
Hi do you still have the C5OE-C 4bbl. 5B19 intake?
Graeme
Offline bryancobb
  • Silver Level Subscriber
  • 2009 Ridn' Around
« Reply #5 on: July 13, 2010, 05:28:53 PM »
Hello all;
WATER PUMPS:
C6OE-A Iron
C3OE-A Aluminum
Thank you!
Ken Mann
Do you still have the C60E-A water pump?  Is it NOS or does it need rebuilt?
66 Metuch Conv
Nightmist, Std Blu Int
Offline GM
« Reply #6 on: August 18, 2010, 10:05:20 PM »
Hi i am interested in the 5b dated intake manifold do you still have it?
Graeme
Offline 5F09CNot4Sale
  • If it does not fit, you need a bigger hammer!
« Reply #7 on: November 08, 2010, 06:57:59 PM »
Is this Block still avaible?
5F09C3031XX Sept 28 64 Dearborn
5F07F1838XX June 29 64 Dearborn
Offline mustangmann
« Reply #8 on: November 10, 2010, 01:08:02 AM »
Hello;
I will check tomorrow and see if I still have this block.  I will let you know.  Thanks!  Ken
Offline GregM
« Reply #9 on: February 17, 2011, 10:19:14 PM »
Interested in this block for my 12/21 k code. Let me know if its available. Do you have the crank and rods for it ?
Greg
Greg M
5F07K..............
5R07K..............
Offline craig429
« Reply #10 on: February 17, 2011, 10:36:24 PM »
Not engine parts, but I need two OEM front drums for a 67 289 coupe.  I have some finned ones and I need some non-finned drums.
I also need OEM rear brake wheel cylinders with small bleeder valves also from the 67 289 coupe.
Do you happen to have any?
1969 Mustang Mach1 390
« Reply #11 on: February 18, 2011, 12:29:11 AM »
Any luck on that Finding that C5AE-E 6-Bolt 289 STD. Bore 4J4 ?
Brian
Offline must69
« Reply #12 on: July 09, 2013, 04:54:06 PM »
 Ken,
Is the
C4OE-8505-A Aluminum water pump still available? Is it rebuilt? Is it an OE pump?
Phil
