Author Topic: Body Plugs  (Read 1518 times)
Offline MWM
Body Plugs
« on: September 12, 2013, 11:33:58 AM »
Good morning,
I have checked the assembly manuals and did a search on the forum, but did not find what I need. I am looking for a clear diagram of where and where not to place the rubber body plugs. My concern is I may add a plug, but it should be open for drainage or vis versa. Car is a May 1965 SJ GT fastback.
Thank you!
Re: Body Plugs
« Reply #1 on: September 12, 2013, 01:34:26 PM »
William,
  The book is about the only source. It shows the "where", it would be impractical to show "where not".
Re: Body Plugs
« Reply #2 on: September 12, 2013, 11:10:13 PM »
Good morning,
Thank you!
Don't think there is a "clear" diagram besides allot of different angles and locations so a single diagram would be difficult or poor from the graphic perspective. Things aren't that easy - if you want them correct ;)  Work a section then move on to the next would be my recommendation
Offline MWM
Re: Body Plugs
« Reply #3 on: September 13, 2013, 09:54:34 AM »
Thank you everyone!
I think I have most of it pieced together, but am a little confused on one area. Where the parking brake cable passes over the rear frame rail, there seems to be a hole on the top side of the frame rail. Does that get a plug? You have to stick your fingers in the tunnel where the parking brake cable passes through and feel on top of the frame rail.
Thank you!
Re: Body Plugs
« Reply #4 on: September 13, 2013, 10:24:58 AM »
A pic of that area might help.  Would it happen to be the rear seat platform turn-up?  There is usually a rubber plug on both ends, at least on convertibles.
Offline MWM
Re: Body Plugs
« Reply #5 on: September 13, 2013, 12:34:14 PM »
Thank you Charles!
In the attached photo, where the parking brake cable passes though the frame rail, there is a hole. The hole is in the top horizontal surface of the frame rail. You can feel the hole only if you stick your fingers in where the cable goes through.  I did notice there is a plug in the bottom of the frame rail, so I think the top need one also?
Thank you!
Re: Body Plugs
« Reply #6 on: September 13, 2013, 02:44:13 PM »
Thank you Charles!
Thank you!
Believe that is a body buck hole and one of the four that does not pass through into the interior
