Good morning, I have checked the assembly manuals and did a search on the forum, but did not find what I need. I am looking for a clear diagram of where and where not to place the rubber body plugs. My concern is I may add a plug, but it should be open for drainage or vis versa. Car is a May 1965 SJ GT fastback. Thank you!
Thank you Charles!In the attached photo, where the parking brake cable passes though the frame rail, there is a hole. The hole is in the top horizontal surface of the frame rail. You can feel the hole only if you stick your fingers in where the cable goes through. I did notice there is a plug in the bottom of the frame rail, so I think the top need one also?Thank you!
