Author Topic: Rear FB vent question  (Read 5325 times)
Offline 1966GTFB
« on: September 11, 2013, 01:38:16 PM »
I have pulled the rear vent apart and noticed that the chrome has black paint on it, should this be removed or is that correct for a early 1966 SJ FB?
Jeff
SJ Build Date: 9/17
'66 Fstbk: 63A X 26 17J
Re: Rear FB vent question
« Reply #1 on: September 11, 2013, 02:18:48 PM »
The black paint is correct, most don't realize and get the detail wrong.  Be sure to use a satin black, shouldn't be shiny.
Offline 1966GTFB
« Reply #2 on: September 11, 2013, 06:03:10 PM »
Thanks Charles
SJ Build Date: 9/17
Offline C5ZZ
« Reply #3 on: September 11, 2013, 09:54:38 PM »
Be prepared to spend a lot of time cleaning, masking and finally painting them
but once its done they turn out nice.
MCA # 00945
Rangoon Red/Red Interior
« Reply #4 on: September 11, 2013, 09:58:23 PM »
Jeff
That part looks like nothing I recognize: I have a 66 Metuchen FB.  Is that the rear quarter vent?  I had my car completely disassembled except for the rear quarter vents and I simply don't recognize the part in the picture.
Offline C5ZZ
« Reply #5 on: September 11, 2013, 10:09:35 PM »
The screen is not there so it may look different to you.
MCA # 00945
Offline drummingrocks
« Reply #6 on: September 12, 2013, 11:13:07 AM »
Same here.  I have a '66 Dearborn fastback, and I've had the vents completely apart in the not too distant past.  I'm having trouble figuring out exactly what that part is in the picture.
Offline livetoride60
« Reply #7 on: September 12, 2013, 12:00:33 PM »
I had to go look myself.  It's one of these without the screen.
« Reply #8 on: September 12, 2013, 01:14:41 PM »
     Couple more shots.  Brian
« Reply #9 on: September 12, 2013, 01:31:11 PM »
I would be inclined to say flat black. I have three used LH sections (from sources unknown) that are in good condition and the paint is not shiny at all. Same for my 66 "K" Fastback. The screen looks to be natural, the shear of the expanded metal is shiny. The inside deflector inside surface is flat black, the outside of the deflector is grey pot metal, natural. I think a lot of masking is required.
« Reply #10 on: September 12, 2013, 03:19:20 PM »
i did a set of those a few years ago and it did indeed require a lot of masking. i let the car owner do that task. all i did was shoot paint.
« Reply #11 on: September 12, 2013, 11:07:15 PM »
Agree with stain or semi- wasn't flat IMHO and have had dozens apart.  Should have some with original finish around somewhere in the boxes
« Reply #12 on: September 13, 2013, 12:49:57 AM »
It's flat. I took one of mine apart, the left hand rear (C5ZB-63280B46-A), it's painted very sloppy and is more dark gray than black but under the surface where the inside deflector(C5ZB-63280B92-A) holds the screen, it's flat, there is no sheen at all. Also the deflector's ends are painted flat black, probably painted at the same time as the internals without a mask. I did a comparison to flat black in FED-STD-595 (called lusterless there) and on both the Standard's sample and the deflector's ends I see the same lack of sheen. That is what I would expect for a black out effect.
« Reply #13 on: September 13, 2013, 12:53:17 AM »
It's flat................
They are ??? Didn't hear you out in the garage looking at mine  :-X
« Reply #14 on: September 13, 2013, 01:06:52 AM »
The three sections I have are currently sitting on my desk, but they reside in location X07 when they are not needed.
And the status of blower motor part II is - - ?
