Author Topic: Paint for rear center section  (Read 1549 times)
Offline SCJSTU
« on: September 05, 2013, 07:38:46 AM »
What rattle can paint is close for the rear chunk?
1969 Shelby GT350 convertible  4spd-AC built 1-27-69
1967 Mustang S-Code 4-speed built Jan 1967 non therm
1956 Ford F100 Big Window 392 Hemi
1961 Falcon 2 Door Station Wagon 302V8
2004 Mach 1 Azure Blue
Offline rockhouse66
Re: Paint for rear center section
« Reply #1 on: September 05, 2013, 08:46:45 AM »
Stuart - I've been using the X-O Primer because it has a satin sheen to it when dry.  It is also a little darker brown and less "red" than most red oxide primers.  Kind of hard to find though.  You have to find a Tru Value hardware store or buy it on line through Amazon or ???
http://www.truevalue.com/product/Anti-Rust-Enamel-Primer-Red-12-oz-Spray/45108.uts
'66 GT FB
Offline SCJSTU
« Reply #2 on: September 05, 2013, 09:59:22 AM »
thanks Jim............lucky for me my store is a member of TruValue!.....
Offline rockhouse66
« Reply #3 on: September 05, 2013, 10:27:14 AM »
Here is how it looks.
'66 GT FB
« Reply #4 on: September 05, 2013, 02:19:32 PM »
I haven't been able to find a rattle can that produces the correct sheen  (always an incorrect flat :( so I used the same red oxide product (epoxy base - then tint it to the color) I use on the underside of the car. Believe that epoxy base is what was originally used.
With that being said give Jim's product a try ;)
