Author Topic: April 68 C Code Automatic Driveshaft markings  (Read 1018 times)
Offline Oz390
« on: August 27, 2013, 10:24:26 AM »
C code, C4, 2.79 standard rear... GT/CS.  First time I have seen 5 paint stripes, used to 4.  From the front a light (white, light orange?) thin stripe (about 3/8"), then the typical 3 stripes - light green (but the color is odd changes in the light and with the flash almost looks light blue at times....?), pink, white in ~1/2" wide.  And then a  5th thin line again, in a dark green or dark green blue, never seen this one before...  but the others I have done were big blocks.
Is the 5 stripe pattern typical for small blocks of this type/time??
Going to clean and leave alone.  Using wax and grease remover with a nylon scrub pad.
Any suggestions on a finish to use to keep it from rusting too much too fast, Brisbane is warm and humid?  Rust converter, clear coat...??
« Last Edit: September 07, 2022, 02:33:59 PM by J_Speegle »
8R03S : 76A I 2A 15M 72 5 U
Re: April 68 Driveshaft markings
« Reply #1 on: August 27, 2013, 08:58:09 PM »
C code, C4, 2.79 standard rear... GT/CS.  First time I have seen 5 paint stripes, .........
Would instead offer that its not that unusual to find 5 stripes on a 68 driveline. Three for identification the others for some other purposes
I would use an oil or wax. Had too many bad issues (just more work) with clear coats
