Author Topic: 66 SJ coupe front steering assembly  (Read 1467 times)
Offline dgneyman
« on: August 13, 2013, 03:25:06 PM »
Does any one have any suggestions on how to dismantle the portion of the steering and suspension that goes across the bottom of the oil pan.  Car has power steering. any info will help.  Thanks.
Dennis
Re: 66 SJ coupe front steering assembly
« Reply #1 on: August 13, 2013, 03:52:43 PM »
     Usually release it from the idler arm post.  Brian
« Reply #2 on: August 13, 2013, 04:03:36 PM »
I assume you are referring to the center link, tie rod ends, pitman are and idled arm. Remove the cotter pins (don't save them, get new ones); loosen all castle nuts on the above but leave them on loosely to keep items from falling; give a good solid rap on the side of each which should loosen the item (you may have to clean a spot on each part so the metal is exposed, and place a heavy object on the opposite side to concentrate the impact).
A "pickle fork" type tool is the last resort. DO NOT POUND THE EXPOSED STUD.
Get a copy of the appropriate Ford shop manual for your car. It has rebuild steps for the power steering control unit. It's not difficult.
Offline dgneyman
« Reply #3 on: August 14, 2013, 09:50:24 AM »
Thanks Jim and Brian,
I will give it a whirl.
Dennis
