Author Topic: Correct 66 Voltage Regulator?  (Read 890 times)
Offline 66RavenGTCoupe
« on: August 12, 2013, 07:49:29 AM »
Hi Guys and Gals,
Can someone please advise me as to the correct Autolite voltage regulator to use in my Dec 65 Metuchen built 66 GT coupe. Is it the one with the silver script or the one with the yellow script or would either be correct?
Thanks in advance,
Dan.
66 Metuchen, NJ  GT Coupe
Raven, Deluxe Black Int
6T07A1612##
BODY  COLOR   TRIM    DATE   DSO   AXLE  TRANS
    65B     A      66           02M     22          1     6
Buck Tag:
C/O  362  (Customer Order, Rotation Number)
5    M7 (Weld Bay 5, Bucked Dec 7)
PIO (Performance Image Option - GT)
Re: Correct 66 Voltage Regulator?
« Reply #1 on: August 12, 2013, 01:54:28 PM »
Silver script Autolite would be most common.  There is a call-out for cars with A/C and other options to have the yellow script, but I don't recall ever seeing an original A/C car with one.
« Reply #2 on: August 12, 2013, 02:42:11 PM »
The 38 or 42 amp alt used the silver marked reg. Typically A/C cars got the 55 amp  alt which took the yellow stamped reg.
« Reply #3 on: August 12, 2013, 07:51:54 PM »
Silver it is then as I have no AC. Thanks guys!  :D
6T07A1612##
    65B     A      66           02M     22          1     6
Buck Tag:
