Author Topic: Original Ford Factory replacement engine  (Read 1588 times)
Offline CW4macret
« on: August 11, 2013, 12:12:52 AM »
My friend who is also a Mustang lover went to a garage sell and bought an old Mustang engine in a wood crate where the seller’s dad had left it for over 40 years. I will not tell you what he paid for this engine but the buyer and the seller thought this was some old worn out engine that was replaced and stuck in the box the new one came in.  When he and I got the engine out of the crate and got all the old wax paper off the motor we found ourselves looking at a brand new NOS Ford factory replacement motor.  It is a 5 bolt block with 66 heads. What to see some pictures just go to this link.
http://www.4statesmustang.com/Mikesengine.html
Mac
64.5, 5F07D
66 Convertible 6T08T
71 Mach1 429CJ 1F05J
01 Coupe
05 GT
08 GT500
14 GT500
Offline PraireBronze
Re: Original Ford Factory replacement engine
« Reply #1 on: August 11, 2013, 12:39:25 PM »
"brand new NOS"
Uh, no, I don't think so.  I don't know if you still can, but you used to be able to walk up to the parts department at a Ford dealership and order a remanufactured engine.  What you got was a remanufactured engine that was outsourced to any of a number of approved Ford rebuilders.  The mix of parts you have is typical of this process.
- Tim -
1965 Prairie Bronze 2+2 (under construction)
Build Oct '64 San Jose
289 4V Automatic Transmission (A-code clone :P )
Black Std Interior
AC, PS, Style Steels, 1" Drop, Konis
Aluminized 2 1/4 Exhaust, Tri-Ys
Offline CW4macret
« Reply #2 on: August 11, 2013, 03:18:29 PM »
That what I thought I said when calling it a replacement engine.  If you went to ford and bought a 289 this is what you would get.  Remanufactured.
Mac
64.5, 5F07D
01 Coupe
05 GT
08 GT500
14 GT500
Offline ajd350
« Reply #3 on: August 11, 2013, 09:24:42 PM »
The numbers on the deck were used to indicate what size select-fit pistons were to be used in each bore.
MCA #2254
« Reply #4 on: August 12, 2013, 02:00:28 PM »
Thanks for sharing.  Looks like a typical rebuilt engine, the tag is pretty cool.  Might be a neat motor to use for display.  Would have to broken up to be correct for anything.  Has to be one of the last 5 bolt blocks since it has an August casting date.
Offline CW4macret
« Reply #5 on: August 13, 2013, 08:12:29 AM »
Yea the heads were one 66 and one 67 which Mike is keeping for now. We are going to reassemble the short block and sell it since he has no use for a five bolt and my 64.5 has the original in it still.
Mac
64.5, 5F07D
01 Coupe
05 GT
08 GT500
14 GT500
« Reply #6 on: August 13, 2013, 09:59:40 AM »
It's most likely going to be extremely difficult to find someone that has a car that the engine would be date-correct for... seeing as early August '64 was when the switch from 5 to 6 bolt occurred.
