Author Topic: INNER SEAT HINGE COVER  (Read 2904 times)
Offline carlizard
« on: August 10, 2013, 11:59:23 PM »
I think I'm jinxed.  I'm trying to finish my 1964.5 convertible by next weekend.  Finished carpet today.  ready to install seats, 1/4 panels, and door panels.  I ordered a set of "64-7 seat Hinge Covers Neutral."  Guess what?  They don't fit!  Here's a picture comparing the right Ford cover (#C4ZB-6561693-AW  3).
Notice the difference in the attached photo.  Can't seem to locate the right one unless someone knows something I don't.
1964.5 260
Body:   76A
Color:   M
Trim:    89
Date:   30G
D.S.O:  75
Axle:    1
Trans:    6
Offline rodster
Re: INNER SEAT HINGE COVER
« Reply #1 on: August 11, 2013, 01:01:06 AM »
I think it's one of those unique 64.5 parts.  65-67's are as shown in the package.
1965 Dearborn Mustang Coupe
Raven Black - Palomino Pony
1967 Dearborn Mustang Conv.
Wimbeldon White - Red
1984 SVO - 2A
Offline kutzoh
  • Gold Level Subscriber
« Reply #2 on: August 11, 2013, 08:35:12 AM »
Did you keep both originals?
As already stated, another unique feature of the early mustangs. The part is not repo'd for the early cars.
Greg
Offline carlizard
« Reply #3 on: August 11, 2013, 02:13:01 PM »
That's the problem.  I only have the one shown in the photo.
1964.5 260
Body:   76A
Color:   M
Trim:    89
Date:   30G
D.S.O:  75
Axle:    1
Trans:    6
Offline carlizard
« Reply #4 on: August 11, 2013, 03:48:38 PM »
Now I feel really dumb.  I found the part on eBay used and the seller wanted $45.00.  I thought that I'd look through about 8 boxes of Mustang parts before buying it.  Didn't find it.  My last place to look was in my to do box.  Only supposed to have door parts in it.  Well, at the bottom of the box was my missing hinge cover. I usually don't throw anything away particularly if it is "Mustang". The part had a big split radiating from the screw hole.   So now I'll fix it and be done with it!  You're right though.  This part is unique to the 1964.5 Mustang.  Another indication of the year of the car.
1964.5 260
Body:   76A
Color:   M
Trim:    89
Date:   30G
D.S.O:  75
Axle:    1
Trans:    6
Offline CW4macret
« Reply #5 on: August 11, 2013, 10:13:42 PM »
I wonder if you took a vinyl repair kit and filled and re-drilled the holes  if you could make those work?
Mac
64.5, 5F07D
66 Convertible 6T08T
71 Mach1 429CJ 1F05J
01 Coupe
05 GT
08 GT500
14 GT500
Offline carlizard
« Reply #6 on: August 12, 2013, 12:18:38 AM »
I thought about that but upon closer inspection of Drake parts the center, on the back, needs to form a receptacle for the hinge pin.  It would have to be ground off and reformed.  Luckily I found the missing one, repaired it, painted it and it's installed.  Looks like new.  In a pinch though it would  work.  Thanks.
1964.5 260
Body:   76A
Color:   M
Trim:    89
Date:   30G
D.S.O:  75
Axle:    1
Trans:    6
Offline carlizard
« Reply #7 on: August 13, 2013, 10:48:27 PM »
Just heard back from Sanderson Ford.  They will special order correct cover for '64.5 in either black or white from Sanderson Ford, Phoenix, AZ:
Here's what they said: THIS PART IS AVAILABLE      IN BLACK    OR WHITE         HAS TO BE ORDERED        FIVE TO SEVEN DAYS.......CALL ROXANNE    DIRECT (623)-842-8682   ASK FOR SPECIALTY PARTS.........YOUR COST IS  $15.95 PLUS TAX......ENJOY YOUR DAY
1964.5 260
Body:   76A
Color:   M
Trim:    89
Date:   30G
D.S.O:  75
Axle:    1
Trans:    6
Offline CW4macret
« Reply #8 on: August 14, 2013, 01:10:41 AM »
They happen to tell you the part numbers?
Mac
64.5, 5F07D
01 Coupe
05 GT
08 GT500
14 GT500
Offline carlizard
« Reply #9 on: August 14, 2013, 11:56:28 PM »
They did not identify  the part number, but when I filled out their "contact form". I used #C4ZB-6561693-AW.  Then I learned this part number means it is for the driver's side seat.  The passenger seat takes part #C4ZB-6561692-AW.  This link will take you to an eBay seller who has several for sale:http://www.ebay.com/itm/1964-1-2-64-5-64-1-2-Mustang-Bucket-Seat-Side-Hinge-Trim-Piece-Inner-RH-Standard-/130682744726?pt=Vintage_Car_Truck_Parts_Accessories&fits=Model%3AMustang&hash=item1e6d4c6f96&vxp=mtr.
They are all for the passenger seat.  Didn't check for the driver's side.
1964.5 260
Body:   76A
Color:   M
Trim:    89
Date:   30G
D.S.O:  75
Axle:    1
Trans:    6
Offline C5ZZ
« Reply #10 on: August 16, 2013, 11:50:18 PM »
Just noticed your post, I have 2 right side covers with the offset screw
hole but sounds like you are set, good to hear you were able to repair yours.
MCA # 00945
Rangoon Red/Red Interior
