Guys!....I didn't mean to start a debate on this thread. Thank you both for your points of view.
I should clarify that my 66 Coupe restoration is ground up and the first ground up I have ever attempted.
I've owned 5 other Mustangs since the 1970's. Each one was fixed using the ability of my skill level at the time
and then the car was sold. I'm at a point where I believe that a full ground up restoration is within my current skill level.
This coupe is being brought back to life to represent what it looked like from the showroom floor. There is very little rust or corrosion and very few panels need repair. I haven't yet entertained the idea of showing the car or entering it in any car shows here locally. However, that may change later down the road. Reno hosts Hot Augusts Nights and an MCA event in the Spring.
Living in Nevada, I don't need to contend with humidity, moisture, rust or road salts in the winter. It's pretty damn dry most
of the year. This morning we're at 35%. However, a good rust inhibitor is being sprayed on the body and frame as I work preserving
this car.
The photos posted are of an area that needs repair. I subscribe to the idea of preserving as much of the original sheet metal as possible.
This quarter panel will need three patches. One, that replaces the rusted out wheel well fender and lip. Two, a small patch to the bottom of the rear
tire area. and three, a patch for the outer rear wheel housing at the rear of the opening. I have the panel for the quarter panel wheel opening
and lip (needs to be trimmed) and I ordered the outer wheel well rear patch panel. The third panel will be made from the left over pieces.
So my questions are:
1. Do these panels get welded by over lapping or do I use a "butt" weld? What is the preferred method?
2. I don't see any spot welds in what I removed or what will need to be installed. I do have a spot weld drill set
and welding tip.
3. My thoughts are that the outer wheel well patch get welded in first, followed by the wheel well fender lip and finally the rear outside bottom.
What do you guys think?
I've read alot about welding and installing panels and there seems to be many avenues to get the job done. I'm looking for
what works best in this situation. Of course I don't want the welds to show, don't want waves or wrinkles in the panels so, what
procedure would work best?
Thanks again for all your input and advice. I'll post finished photos when the jobs complete.
Jeff
