Author Topic: Passing gear linkage  (Read 1227 times)
Offline dgneyman
« on: August 06, 2013, 01:16:43 PM »
Trying to find out if anyone knows if a Jan 66 SJ built coupe should have linkage to the Carb from the C4 trans for a passing gear.  Has a 289, 2v and C4 auto.  Any info will help.  Thanks.
Dennis
Re: Passing gear linkage
« Reply #1 on: August 06, 2013, 02:09:05 PM »
the accelerator rod has a link pointing downward which connects to a cable which connects to the kickdown lever on the trans.
Offline dgneyman
« Reply #2 on: August 06, 2013, 03:31:12 PM »
Thank you sir,
This car seems to be missing all of of the passing gear linkage to the trans.  Do you or anyone have a picture of what it looks like?  Thanks.
Dennis
« Reply #3 on: August 06, 2013, 03:37:24 PM »
sorry i don't have any pics but the factory shop manual has some good illustrations of that area. you may also try a google search for 'C-4 kickdown'.
Offline C5ZZ
« Reply #4 on: August 06, 2013, 03:48:42 PM »
You should have the cable setup on yours, early 65's used
a rod but your 66 would have the cable setup like pictured.
Your accel bellcrank should have a arm that points down,
the cable hooks onto it, other end of the cable hooks onto
the small lever on the side of the trans.
MCA # 00945
Rangoon Red/Red Interior
Offline dgneyman
« Reply #5 on: August 06, 2013, 06:15:37 PM »
Thanks for the info and pics gentlemen,
I reckon I will attempt to find the parts and get them installed.
Dennis
Offline dgneyman
« Reply #6 on: August 07, 2013, 03:55:44 PM »
You all are great.  Thanks again for the info.  I found out that the car has the linkage minus the cable which attaches to the trans.  Should be able to locate that and get it hooked up.  Thanks again.
Dennis
