Author Topic: Tie Rod Adjusting Sleeves  (Read 7447 times)
Offline Sunlitgold68
« on: July 29, 2009, 12:57:35 PM »
What is the finish on the tie rod adjusting sleeve and nuts/bolts. Was thinking phosphate would be OK on the sleeve? Thanks
8T01C204XXX
Built May 14th, 1968
Re: Tie Rod Adjusting Sleeves
« Reply #1 on: July 29, 2009, 08:30:09 PM »
They should be bare steel but dark heat treated line all the other steering stuff. If your really doing phosphate the finish will be a bit flat but if you oil them they might smooth out and darken . Originally a not darker and smooth than phosphate - in look
Offline Armond
  • Silver Level Subscriber
    • D'Agostini Restorations.com
« Reply #2 on: August 06, 2009, 04:38:24 AM »
The replacements were darker than the originals.  almost a blued coating.  originals on the car were a lighter being stamped and rolled steel.  Not really that dark in my opinion. Phosphating is a great way to help them maintain.
MCA#31064
