Author Topic: Correct Screws ?  (Read 1633 times)
Correct Screws ?
« on: August 04, 2013, 01:00:48 PM »
    Fast Back interior question.  Some pictures of the screws I used to attached the interior quarter surrounds to the trunk/trap door frame.  Three vertical screws in the center of the trunk photo.  I put these in sometime back and I know they can't be right.  What is the correct attachment method.  Photo ? Thanks,  Brian
Offline 2+2=GT350
Re: Correct Screws ?
« Reply #1 on: August 04, 2013, 02:07:15 PM »
Brian, If I remember right the screws on the trim at the trap door are popriveted in place. Maybe someone else can confirm. I will be installing mine next week, and fairly sure I remember drilling the rivets out to remove trim in this area
« Reply #2 on: August 04, 2013, 03:20:05 PM »
Agree that they should be pop rivets, believe there was a small rivet size used early in '65 production and then went to a larger size.
« Reply #3 on: August 04, 2013, 03:25:53 PM »
You need to invest in a set of Mustang Assembly Manuals. The rivets in question are 380098-S, a 3/16NOM,0.450BODY L,0.375HD,0.188-0.250GRIR,STL. They are different than what was used in 1966. I got my replacements from a local hardware store.
« Reply #4 on: August 04, 2013, 03:41:36 PM »
     Thanks guys for jogging my memory. Now I remember when I was removing the interior for refreshing thinking what a bad idea rivets were.  Brian
