Author Topic: Steering Column Removal  (Read 3362 times)
Offline koski19
« on: August 03, 2013, 12:31:10 AM »
My turn with a question. I spent this afternoon removing front brakes and suspension. I now need to remove the steering column from the gear box. 1966 Coupe 6 cylinder w/ power steering.
How's it accomplished?
Jeff
Offline NEFaurora
Re: Steering Column Removal
« Reply #1 on: August 03, 2013, 01:04:34 AM »
On '65- Early '67, The gearbox and column rod are considered one-piece for removal.  You have to first remove the outer steering column from the interior side, then 2nd, remove the gearbox and inner rod as one-piece from below.  You have to really jack up the front of the car real high to do it, but you can do it.  It's best to use an automotive lift to remove the gearbox and rod if you can get access to one.  It makes it so much easier.  That's why they call it the spear-o-matic...because its all one-piece... It's also why, when people know that they are upgrading the steering column to an aftermarket unit, They just cut the rod...to make removal easier..
Tony K.
MCA#70001
« Reply #2 on: August 03, 2013, 01:37:22 AM »
Jeff
Jeff,
Get a 66 Comet, Falcon, Fairlane and Mustang Shop Manual. Section 3-3 is dedicated to manual steering. Unless you have replacement bearings and replacement balls I would not recommend opening the box. That section does cover adjustments. If your steering box is too badly worn, find a used replacement or send yours out for a rebuild.
Offline koski19
« Reply #3 on: August 03, 2013, 09:10:33 AM »
Jeff,
Hey Jim,
I do have the service manual mentioned and looked at the section, but didn't quite understand it. That's why I asked. I have the coupe down to the unibody. The gearbox, steering column is the last piece to be removed. I believe that the gearbox is worn out and needs rebuild. There's just too much play in the steering wheel. Know of a rebuilder? I haven't yet checked locally.
jeff
« Reply #4 on: August 03, 2013, 07:10:52 PM »
On '65- Early '67, The gearbox and column rod are considered one-piece for removal.  You have to first remove the outer steering column from the interior side,....................
Tore a number of headliners doing it that way - so be careful if that is your method of choice. I rather unbolt it from the dash, wrap the head of it in a towel so that it does not stain the drivers seat as it comes down to contact it, them unbolt the box (pittman arm already detached). Slip the steering box out, then remove the column if needed.
Just me ;)
