Author Topic: 69 Mach I/Grande door panel speaker cut out  (Read 5536 times)
Offline 7Lscjracer
« on: August 02, 2013, 02:09:58 AM »
Are there plastic inserts to accept a screw surrounding the speaker hole to mount either the speaker or the grill, or do the screws just go directly into the sheet metal?
Grill screws are readily available, but I can't find any info on the speaker mounting screws, and I need a set of 8 thanks.
Bought May '81, sold Sept '20
Re: 69/70 door speaker cutout
« Reply #1 on: August 02, 2013, 05:35:04 PM »
No plastic thread inserts  that I can remember
Offline jmlay
« Reply #2 on: August 02, 2013, 11:54:54 PM »
I can only speak for my SJ Mach1. Screws go right into the sheet metal.
Mike
1969 Mach1 428 CJ Ram Air
San Jose
Scheduled Build: 1/2/1969
Actual Build: 1/3/1969
Released: 1/8/1969
Offline 7Lscjracer
« Reply #3 on: August 02, 2013, 11:55:46 PM »
Thanks all, that will make it easier to repair my doors.
Unlikely I'll find a factory speaker door pair, but now I can use plain doors and make the cutouts.
I see there are templates on eBay.
What I really need are just the section of the door in that area to stitch into my original doors.
Doors rusted out underneath are usually still good where the speaker goes, and are all I need for donors.
« Last Edit: August 02, 2013, 11:57:59 PM by 7Lscjracer »
Offline jmlay
« Reply #4 on: August 03, 2013, 10:17:41 PM »
The speaker hole looks like it was cut with a dull butter knife.  8)
Mike
San Jose
Released: 1/8/1969
Offline DEWilson
    • Maine Mustang Back from the Dead Restoration Shop
« Reply #5 on: July 29, 2017, 09:09:46 PM »
  hi  door speaker cut out  as for the door panels  i see marking on the back of the panels  to punch out ..... but my question is how is the carpeting cut size wize is the bottom cut off ?  work a april 1 69 nj built car....
 plus how was hole cut into the door  pic would help
Thank you
« Last Edit: July 31, 2017, 03:57:15 PM by J_Speegle »
Re: 69 door panel speaker cut out
« Reply #6 on: July 29, 2017, 10:21:36 PM »
Guess your working on a Mach I or a Grande?
Carpet was normally cut off following the back side as a guide. So its (for lack of better words) is a whole with the bottom edge open /no door panel or carpet edge
Will look and see if I have some pictures of that area and a door panel and post.
« Last Edit: July 29, 2017, 11:07:05 PM by J_Speegle »
« Reply #7 on: July 29, 2017, 11:09:19 PM »
Had to look into my 70 examples before I found a Mach I or Grande door with panel in place but speaker and grill removed
Sorry they are not the best but the focus at the time the picture was taken was not this specific detail
Offline 7Lscjracer
« Reply #8 on: July 30, 2017, 01:30:51 AM »
Here's a template for cutting the door:
http://www.ebay.com/itm/69-70-1969-1970-FORD-MUSTANG-MACH-1-DELUXE-DOOR-SPEAKER-TEMPLATE-/382180440492?hash=item58fbbab9ac:g:N70AAOSwzqFY8oHK&vxp=mtr
I haven't been able to find the screws for securing the speaker to the door.
Last I checked that part number wasn't available from AMK.
Not sure if the grill mounting screws are black or silver colored either.
Repro grills look pretty good from the front, but don't have the paper and foam strips on the back of the grill surprise, surprise.
« Reply #9 on: July 30, 2017, 04:23:52 AM »
Silver - look to be zinc or cad not chrome
Offline DEWilson
« Reply #10 on: July 31, 2017, 12:44:41 PM »
Thank you     yes is a mach 1    so the grill cover is onto the carpeting when screwed down  ont the top and sides   so the only door tempate is a ebay one
Re: 69 Mach I/Grande door panel speaker cut out
« Reply #11 on: July 31, 2017, 03:56:50 PM »
Thank you     yes is a mach 1    so the grill cover is onto the carpeting when screwed down  on the top and sides
Don't understand. There are four screws one at each corner - that have nothing to do with the carpet
The carpeted section of the door panel is cut on three sides, top, front and rear edges leaving the bottom of the cutout open. No carpet or vinyl trim visible below the speaker cover
so the only door template is a ebay one
That template that is being sold is for cutting the door if your adding speakers or have replaced the door(s) during the restoration not for the door panel.
Is it the only one? Sure there are other ways to get that template 7Lscjracer was just offering one he had found
Offline 7Lscjracer
« Reply #12 on: July 31, 2017, 04:22:12 PM »
The grill pins the carpet down at the top and sides
If you look at the grill the bottom is thicker so it reaches the door metal and the sides and top are thinner to accommodate a little perimeter of carpet underneath
If your grills are the same thickness all around then they're for standard door panels
« Reply #13 on: July 31, 2017, 04:53:47 PM »
A few pictures to help
Holes for speaker and holes for grill mount/attachment
Appears that something has been dropped on the top edge of the speaker holes - reason why its not perfectly oval ;)
« Last Edit: July 31, 2017, 04:56:21 PM by J_Speegle »
Offline DEWilson
« Reply #14 on: August 02, 2017, 10:34:55 AM »
Thank you      for the pic   now i can do the job correct thank you all
