Author Topic: Markings on inner fender - Dearborn D code  (Read 1722 times)
Offline CW4macret
« on: July 26, 2013, 05:15:06 PM »
Found this while removing undercoat on my 64.5 D code
« Last Edit: May 18, 2020, 05:25:22 PM by J_Speegle »
Mac
64.5, 5F07D
66 Convertible 6T08T
71 Mach1 429CJ 1F05J
01 Coupe
05 GT
08 GT500
14 GT500
Offline ChrisV289
Re: Markings on inner fender
« Reply #1 on: July 26, 2013, 06:41:33 PM »
What did you use to remove the undercoating?
2009 V6 Mustang Coupe
Offline CW4macret
« Reply #2 on: July 26, 2013, 07:28:27 PM »
hand scraper and hard bristle brush
Mac
64.5, 5F07D
01 Coupe
05 GT
08 GT500
14 GT500
« Reply #3 on: July 26, 2013, 08:59:58 PM »
Dearborn car??
What inner fender panel - driver's side forward???
Offline CW4macret
« Reply #4 on: July 27, 2013, 03:45:45 AM »
Yes
5F07D164778
Body 65A
Color Y
Trim 82
Date 12F
DSO 54
Axle I
Trans 5
Mac
64.5, 5F07D
01 Coupe
05 GT
08 GT500
14 GT500
Offline CW4macret
« Reply #5 on: July 27, 2013, 03:49:51 AM »
driver's side forward just behind the radiator core support
Mac
64.5, 5F07D
01 Coupe
05 GT
08 GT500
14 GT500
« Reply #6 on: July 27, 2013, 06:31:35 PM »
Thanks for the additional info - helps:)
Not sure the purpose of these marks that were added at Dearborn that are over the black - not to be confused with the ones under that were likely pallet data
What your seeing (rest is likely covered by the sound deadener) is the bottom row of what should be three rows of two numbers each. So far the numbers used in the pattern were 0-6 normally applied in white or yellow. Yours are a bit thicker (worker must not have sharpened the crayon for that car) than other examples. Marks can be found on the drivers side but also (a few in the sampling were on the drivers side - likely a different shift or different worker that shift) Have only seen these in 65 Dearborn production
That's all I have on the subject currently
