this is from the car in my signature. 14th dec 67. power disc brakes. the old paint is coming off like rubber in places.I can also make out lettering under the sticker, but I cant make it out.. I can see brake written. maybe it says disc brake? I will keep trying to read it
jeff, just had the picture of that cap show up.I can see much bigger lettering under my sticker. I will try again to read it.
Jeff, I believe the master cylinder cap you are showing is from a Mopar application. Remember, the caps themselves fit the same between certain Mopars and the Ford applications.
Marcus, great article. I have an original 68 cap that has the W on the top larger sloped surface. It appears to have another letter stamped in the area that Scott's pic has the W. Cant make it out put I will pull it off and look closer. I'll send you a pic
I just found one with a "W" as mentioned by Tim. When I did a compare to another, I found that the other had the "W" on the inside. Comparing the two, the location and spacing of the stamping is different - I put a ruler up to highlight the difference.
