Restoring a 4 spd close ratio S-code. My question is this, what is the correct distributor casting code for this vehicle. Mine is a 67 part number with 69 date code. Any help is appreciated.
Is it a C7OZ-12127-F or G?
It would be marked C7OF-12127-F or G from the factory. The "Z" in the fourth position of the part number indicates a service part number and would not (normally) be marked on the part. There is also an indication that this distributor was use on AT equipped cars with no reference to carburation, which may be the "G". This is in addition for the other listing used on every transmission option for four barrel cars. Fords abbreviations leave a lot to be desired.JimJeff - An answer yet?
I think my car's distributor is from another car. Has C7AF-12127 A G
The application for the -AG is shown as: 390CID; 67 only; full size Ford, Fairlane; 2 barrel carb; AT; without smog.It's most likely a rebuilt installed by a previous owner (who was just trying to help ).Jim
