Author Topic: engine paper decal  (Read 1207 times)
Offline saacman
engine paper decal
« on: July 12, 2013, 09:06:21 AM »
would like some info. if possible  looking for correct info. for the paper sticky decal that went on the front engine block . i notice in the aftermarket they have quite few different ones. Info on car is as follows: 9/69 Dearbon built (Sept.29 '69 actually date of build) ,  428 CJ Ram- Air , Mach 1, 4- speed toploader. hope this is all that is needed to get correct decal  all help is grt8ly  appreciated .
Re: engine paper decal
« Reply #1 on: July 12, 2013, 12:21:59 PM »
Do you have the original aluminum engine ID tag?  The engine identification number will be on there.  Here is some info that might help: http://www.fordification.com/tech/engineIDtags.htm
If you don't have the aluminum tag, hopefully someone will be able to narrow it down to a single correct answer.
« Reply #2 on: July 12, 2013, 06:18:52 PM »
Paper tag/sticker will go on the front of the passenger side head - no the block
For your 428 CJ 4 speed buildsheets (source of the info) show 420S
Offline saacman
« Reply #3 on: July 12, 2013, 09:21:44 PM »
thank you for all info.  no unfortunately i dont have the engine aluminium tag or the rear end tag, im working with Kevin Marti to acquiring those
