Author Topic: Master Cylinder ID and Bore ?  (Read 1941 times)
« on: July 10, 2013, 09:37:55 AM »
      How to ID a correct OE Disc brake master cylinder ?   The cylinder bore size for a 65, San Jose, GT car built about mid May 65 ?      Thanks,  Brian
« Last Edit: July 10, 2013, 10:09:59 AM by Brian Conway »
Offline mgmradio
Re: Master Cylinder ID and Bore ?
« Reply #1 on: July 10, 2013, 12:39:21 PM »
An original 65 master cylinder will have brass adapters with the seats screwed into the outlets. In 66 they changed them and put the seats in the ports.
« Reply #2 on: July 10, 2013, 04:30:13 PM »
     Thank you for the info on the seats.  Appears this master cylinder is a 66 version, has a 15/16" bore and some cast info on the down side.  That info is;  2225052  ?R5  and what seems to be a date code 2 8 5.  Mean anything ?  Brian
« Reply #3 on: July 13, 2013, 05:41:15 PM »
     Thank you for the info on the seats.  Appears this master cylinder is a 66 version, has a 15/16" bore and some cast info on the down side.  That info is;  2225032  ?R5  and  a date code 2 8 5.
     I have learned, credit Chockostang, that the 222 identifies a Bendix unit and that the ?R5 is the Bendix logo a winged ' B ' R5.  Still don't know what the BR5 means and not sure how to decode the date casting but am going to guess; Month, Day and year.  Have a picture, pretty dark, but could this be the original Master Cylinder for my 65 ?   Opinions ?  Brian
« Last Edit: November 27, 2016, 11:54:54 AM by Brian Conway »
« Reply #4 on: November 24, 2016, 07:28:59 PM »
I'd like to re visit this topic ?  The master cylinder is off the car and I have some more info.  It appears it is the 66 version with seats installed in the ports ?  A Bendix unit with a date casting of 2 8 5.  Same question OE or not ?  Thanksgiving day riddle.   Brian
I have been told that Bendix used the Julian Calendar method to date their master cylinders.  Makes sense because that is the method used on the K/H proportioning valve.   So 285 th day or Oct. 12, 1964 ?  Brian
« Last Edit: November 25, 2016, 10:43:46 PM by Brian Conway »
« Reply #5 on: November 28, 2016, 05:57:45 PM »
Thank you Autolite for the additional information.  My car, May of 65, would be in the later 65 production year.  Brian
« Reply #6 on: November 28, 2016, 06:15:26 PM »
A date code of Oct 12 1964 would indicate a master cylinder that used the brass adapters . A Oct 12 65 dated master cylinder would have the seats installed in the ports.
