Author Topic: 65 Battery Tray  (Read 3742 times)
Offline rodster
65 Battery Tray
« on: July 10, 2013, 12:34:29 AM »
Thought this was covered before but didn't find anything with a search.
Battery tray with a date code stamping.
65 Dearborn car with a April 19th scheduled build date.
1965 Dearborn Mustang Coupe
Raven Black - Palomino Pony
1967 Dearborn Mustang Conv.
Wimbeldon White - Red
1984 SVO - 2A
Offline rodster
Re: 65 Battery Tray
« Reply #1 on: February 01, 2015, 06:45:20 PM »
Is the bend at the bottom typical of an original 65-66 battery tray?
If so, it's a tell tail sign of an original as is the radius of the upper bend.
Thought I'd show a comparison of a current repop.
1984 SVO - 2A
Offline drummingrocks
Re: 65 Battery Tray
« Reply #2 on: February 02, 2015, 11:19:49 AM »
Wow, I had no idea the repros were that far off!  I always wondered why I had to force them to bolt up properly!   :o
Offline DM_1964
Re: 65 Battery Tray
« Reply #3 on: February 02, 2015, 09:36:28 PM »
I'm sure the manufactures say "Eh, close enough, good enough"...
Regards,
Dom
Re: 65 Battery Tray
« Reply #4 on: February 03, 2015, 09:37:41 AM »
Right.  It'll fit....after some careful modifications with a 40lb sledgehammer!   :D
Offline rodster
Re: 65 Battery Tray
« Reply #5 on: February 10, 2015, 02:42:24 PM »
Found this picture of a NOS battery tray.
Seems a NOS piece is closer to the repop as opposed to the original as far as the bend in the support leg?
« Last Edit: February 10, 2015, 02:48:50 PM by rodster »
1984 SVO - 2A
Re: 65 Battery Tray
« Reply #6 on: February 10, 2015, 08:25:59 PM »
Your original may have been bent.  Also, not uncommon for service replacement parts to not match original factory line pieces... and then repro makers using NOS parts to copy.  You'd be best finding some other original battery tray samples to compare and then decide what you want to do.
Also... consider that the battery tray may have gone through some revisions from original issue and the NOS piece is modeled after the last version.
Offline rodster
Re: 65 Battery Tray
« Reply #7 on: February 10, 2015, 08:39:02 PM »
Lots of good points.
The radius of the lower bend looks too tight and clean to be done by accident, but perhaps it could be?
I agree, examples of originals would be nice to see, hence my previous question.  You can bet I'll be looking for this detail if I come across any original cars.  ;)
1984 SVO - 2A
Offline ChrisV289
Re: 65 Battery Tray
« Reply #8 on: February 11, 2015, 12:06:06 AM »
I just took some pictures of my original battery tray.  (excuse the dirt as I am still detailing the car for Tucson)  Hope this helps:
2009 V6 Mustang Coupe
Re: 65 Battery Tray
« Reply #9 on: February 11, 2015, 01:06:47 AM »
The date code stamps separates the genuine from a repro although I have encountered a few OEM trays without date code stamps too. The vast majority of genuine ones have the stamping then not.
Offline rodster
Re: 65 Battery Tray
« Reply #10 on: February 11, 2015, 10:03:50 AM »
Thanks!
Looks more like the repop but much cleaner bends.
1984 SVO - 2A
Re: 65 Battery Tray
« Reply #11 on: February 11, 2015, 02:02:26 PM »
Just had to go look.  The tray on my San Jose car has the same date stamp as Rodster's first picture.  My 5R09A car scheduled build June 1 actually was a little earlier as it was picked up at the dealership May 29.  Battery tray date stamp 4 5 2D.  There also seems to be a date stamp on the radiator support wall in this same general area.  Brian
Offline rodster
Re: 65 Battery Tray
« Reply #12 on: February 11, 2015, 06:35:17 PM »
More than once I ran out to the garage at night to check on something.  ;)
Wow, what are the chances of the same date code?  :o   Another good picture of an original battery tray.  I'm beginning to think the extra bend in mine was due to the weight of the battery and the surrounding area being weakened by the rust.
Thanks for looking and reporting back  :)
« Last Edit: February 11, 2015, 06:53:08 PM by rodster »
1984 SVO - 2A
