Author Topic: Need help on battery hold down  (Read 1620 times)
Offline kevin1221
« on: July 07, 2013, 09:10:23 PM »
I have a 1966 Coupe that I'm getting ready for Grand National show over labor day. I show in concourse driven.
Ay my last MCA National in Jacksonville in 2011, I lost a point for incorrect bolt on the battery holddown.
Could someone tell me what the proper bolt looks like.
Thanks for your help.
Kevin
Kevin
Tampa FL
1966 Mustang Sprint 200ci Six - Automatic
Scheduled Build date : 7-7-66 - Dearborn
MCA Concourse Gold winner (Multiple)
MCA Conservator Award
AACA Sr Grand National 1st (Repeat)
Currently own 2008 Shelby GT
Re: Need help on battery hold down
« Reply #1 on: July 07, 2013, 09:30:09 PM »
Would be better if you remove the bolt/nut and take a picture.  Hard to tell what you have when installed on the car.
Offline kevin1221
« Reply #2 on: July 07, 2013, 10:06:10 PM »
Thanks Charles. I will get more detailed photos but it will most likely be next weekend before I'm able to get them.
I'll post these additional pics as soon as I can.
Kevin
Kevin
Tampa FL
Offline kevin1221
« Reply #3 on: July 14, 2013, 12:37:36 PM »
Attached are the pictures of the bolt I am currently using.
Any help you gave give will be appreciated.
Thanks.
Kevin
Kevin
Tampa FL
« Reply #4 on: July 14, 2013, 02:20:22 PM »
The carriage bolt could be a little longer and there is usually a locking nut to hold it to the battery tray.  There are some variances of fasteners used.
Offline kevin1221
« Reply #5 on: July 14, 2013, 03:38:39 PM »
Thanks Charles...I appreciate the feedback.
Kevin
Kevin
Tampa FL
« Reply #6 on: July 14, 2013, 06:22:00 PM »
The bolt/clip I've seen on 65 and 66 San Jose built cars looks like the bolt/clip used to hold the rear center of the front fenders to a bracket on the "A" pillar, only longer. That fender bolt/clip in fact it is the same one used to hold the optional battery. The optional bolt/clip is p/n 379924-S2, 5/16-18X1 5/16 in long, the standard is p/n 380582-S2, 5/16-18X2.0 in long. The nut is 55736-S2, the same nut used for the horns. Because of battery acid leakage, the bolt/clip and nut get corroded to nothing in a short time. Replacements were almost anything. I recommend using some Permatex battery anti-corrosion spray in and around that area, and wipe it off for shows.
Offline kevin1221
« Reply #7 on: July 14, 2013, 08:11:54 PM »
Thanks Jim, I appreciate it.
Kevin
Kevin
Tampa FL
