Author Topic: Help needed on ID various engine parts on a Hi-Po 289  (Read 2544 times)
Offline silverfox
« on: July 05, 2013, 08:13:53 PM »
Hi everyone.
I'm in the process of taking out a Hi-Po 289 out of my '66 GT350 clone and I could do with some assistance because the Hi-Po motor in the car appears to have a mix of Hi-Po non-correct and correct parts.
Help needed to verify the oil pan, oil cooler, fuel pump and fan.
Many thanks
Oil pan - Genuine cobra unit (I think it may be genuine?)
Oil Cooler
Fuel pump
Fan
It seems that this is from a 429 engine ?? (see link below)
http://books.google.co.uk/books?id=MFrxUXmxQuwC&pg=PA46&lpg=PA46&dq=c9ze-d+fan&source=bl&ots=ycAGuH-jOc&sig=iUysFdQEgGIr3N8BfpFHiKeGzvQ&hl=en&sa=X&ei=mk_XUenzHaSM7Ab8tYHgDw&ved=0CGIQ6AEwBg#v=onepage&q=c9ze-d%20fan&f=false
Current Mustangs:
1965 Fastback 289 K Code - Hi-Po - Caspian Blue
1970 Mach 1 Sportsroof 351C Auto - White - Project car and in Resto (started Sept 2012)
Past Mustangs:
1966 Fastback GT350 clone, Hi-Po 289, 4 Spd Man, White/Blue
Offline tim_morrison82
    • Click Here for My Project
Re: Help needed on ID various engine parts on a Hi-Po 289
« Reply #1 on: July 05, 2013, 11:49:10 PM »
I cant really help with specific parts, but bob mannels ford small block book would definately help you! its a bible for engine parts id.
« Reply #2 on: July 07, 2013, 11:43:56 PM »
Difficult to tell the COBRA oil pan over the internet - often comes down to weighing it and comparing that measurement to originals. Many repo have no additional markings
Oil filter holder is an after market unit
Fuel filter is an over the counter pump - might be a carter but does not have the normal markings but not original to a Hipo
Offline silverfox
« Reply #3 on: July 08, 2013, 04:00:25 PM »
Thanks for taking the time to look and post guys.
Jeff, on the oil pan, it will be coming off in the next week or so, anything in particular I should look for ?
Current Mustangs:
Past Mustangs:
« Reply #4 on: July 08, 2013, 11:10:49 PM »
A little reading  here might answer some of your questions
http://saacforum.com/index.php?topic=13054.15
Offline silverfox
« Reply #5 on: July 09, 2013, 06:20:35 PM »
Jeff,
Thanks, that's very, very helpful.
regards
Current Mustangs:
Past Mustangs:
