Author Topic: Mach 1 hood black out paint  (Read 2659 times)
Offline 6770shelby
« on: June 30, 2013, 10:10:10 PM »
I am looking for a recommendation of paint and texturing materials to be used for the blacked out portion of hood.
Re: Mach 1 hood black out paint
« Reply #1 on: June 30, 2013, 11:59:51 PM »
What year are you working on - originally different paints were used for 69 & 70?
Offline drummingrocks
« Reply #2 on: July 01, 2013, 09:37:57 AM »
I have had excellent luck with SEM's Hot Rod black paint.  It goes on shiny, but dies back to the correct matte sheen.  It doesn't have a texture to it.  It's a catalyzed urethane, and so far, it's been extremely durable.  I've seen lots of cars with incorrect black, either too shiny or too dull looking.  To me, this is a dead ringer to what originally came on my '69 Mach.
http://www.amazon.com/Sem-Products-Hot-Rod-Black/dp/B002O0OTTC/ref=sr_1_1?ie=UTF8&qid=1372682214&sr=8-1&keywords=sem+hot+rod+black
Offline 6770shelby
« Reply #3 on: July 01, 2013, 02:55:22 PM »
It's a 69 - sorry.
« Reply #4 on: July 01, 2013, 08:38:43 PM »
It's a 69 - sorry.
No problem but as mentioned 70 and 69 used different paints for the same thing.
Believe that the factory packs may still be available from PPG/Diltzler # 9295
Understand that the following company reformulated the color with currently available paints and has it available - use to see their ads on Ebay
http://www.autocolorlibrary.com/
Offline DaveF
Mach one hood treatment
« Reply #5 on: April 26, 2024, 11:19:56 AM »
I?m getting ready to paint the hood stripes on my Mach One. I am having difficulty figuring out what type of paint to use. My old stripes were matte black, with some notable texture. Is there someone that can let me know how to make authentic stripes. If you recommend products, please be specific. I would appreciate exact paint code numbers if possible. Thanks
« Last Edit: April 26, 2024, 02:05:28 PM by J_Speegle »
1970 Mustang Mach One
428 SCJ w/Drag Pak 3.91
Metuchen plant
Built 9/5/1969
Re: Mach one hood treatment
« Reply #6 on: April 26, 2024, 02:04:46 PM »
Is the paint on your hood original?   If so that's good as you can use it to make a pattern of the outside forward curve to use for your repaint.
The 69 paint is different from the 70 type so don't get the two mixed up. Originally it was a Ditzler/PPG product #9295but that will do you little good now. The original PPG/Ditzler formula has not been available for decades but TCP Global reformulated current paints to work for this task. Latest I've seen it guys purchasing the correct 69 (70 is different) paint from TCP Global. If you call they will know what paint it is. They also use to sell the product on Ebay, not sure they do any longer
TCP Global Auto Paints
https://tcpglobal.com/pages/automotive-paint-home
Library for older cars
https://www.autocolorlibrary.com/
Related thread though it focuses on SJ cars
https://www.concoursmustang.com/forum/index.php?topic=17954.msg113765#msg113765
  If you lack the original pattern (take allot of measurements) there are patterns for the curve and distances between the stripe, blackout, forward hood edges that can be posted though I'm always concerned how well the curve gets reproduced from scanning and reposting but it you size it to match the side and forward line you should be in the neighborhood.
Worked for me
