Author Topic: 1965 Mustang GT Leaking Cap on Master Cylinder  (Read 1735 times)
Offline rocket289k
« on: June 30, 2013, 02:16:53 PM »
Hi Guys,
The cap on my new master cylinder is leaking.  The master cylinder, the cap and the gasket are brand new.  It's causing quite a mess not to mention messing up the paint in my engine compartment.  Has anyone else run into the issue?
I checked to see if the gasket is installed correctly (as I've seen some gaskets installed upside down with the "plunger" part of the rubber gasket pointing upwards to fit the contour of the cap as opposed to the plunger of the rubber gasket pointing down so it would sag against the brake fluid and eliminate the pocket of air).
Thoughts?
Ron
Offline Jays66gt
Re: 1965 Mustang GT Leaking Cap on Master Cylinder
« Reply #1 on: June 30, 2013, 04:15:50 PM »
Is it a new power set up or an original set up?  I would try tweaking the clamps and see what happens.
1966 GT
6R07A105XXX
San Jose car delivered to Denver in September 1965.
« Reply #2 on: June 30, 2013, 09:21:32 PM »
Not that it will help in this situation but there was a revised master cylinder cap gasket released in the spring of 66 for disc barkes. Design difference a set of ribs on the matting surface with the base.
Offline rocket289k
« Reply #3 on: July 01, 2013, 02:13:39 PM »
Hi Guys,
It is the original style 65 setup (new master cylinder and cap) - didn't rebuild the old unit.  I'm going to try a new cap (the prior one I bought looks slightly bent to my eye).
Ron
Offline rocket289k
« Reply #4 on: July 01, 2013, 02:14:56 PM »
Hi Jeff - I presume the ribs make contact with the master cylinder itself (not the cap lid).
Regards,
Ron
« Reply #5 on: July 01, 2013, 08:41:08 PM »
Beleive so since that is the side with the liquid ;)
Offline rocket289k
« Reply #6 on: July 01, 2013, 08:54:34 PM »
Ha! - well played  :)  The reason I asked it that I've seen some reproduction lids with that gasket installed completely backwards.
