Author Topic: Door Window Adjustment hardware  (Read 930 times)
Offline Angela
« on: June 25, 2013, 12:01:49 PM »
Guys, I have a couple questions concerning the adjustment hardware used with the door glass channels and vent window frames. Here is a link to a picture of the type of hardware I am referring to:
http://thecareandfeedingofponies.blogspot.com/2008/04/door-window-adjustment.html
(1) What was the factory finish? Zinc phosphate?
(2) Are these bolts reproduced by AMK or anyone (I don't see them in AMK's catalog)? OR must the originals be re-plated?
Offline Oz390
Re: Door Window Adjustment hardware
« Reply #1 on: July 15, 2013, 06:51:50 AM »
Which ones, all of them?  Link is for a 65-66, this is 67-68 ...
Believe most of them were phosphate and oil, but without more clarity not sure what items you are referring to.
If you meant the allen head set screws with ring/washer, they are not reproduced as far as I could find a while back.  The rest of the hardware, if not exact is available from AMK in "very close"
8R03S : 76A I 2A 15M 72 5 U
« Reply #2 on: July 15, 2013, 09:26:57 AM »
If the hardware is only lightly rusted soak it in Evaporust and reoil. I have also had good luck junk yarding for good hardware.
Marty
