Author Topic: Radiator Hose Marking -  (Read 1617 times)
« on: June 22, 2013, 12:38:55 AM »
On my 66 "K" engine are two radiator hose marked with the current hose part numbers, C6ZE-8286-A lower and C4ZE-8260-A upper, plus a Falcon service part number, C3DZ-8286-J (?) lower and C3DZ-8260-H upper. This are about the only parts I know of that have an engineering, aka assembly line part number, and service part number, the "Z" in the fourth position, that show up on Mustangs. I got these from Marti Auto and I know that Kevin did a lot of research on the parts he sells, still, did Ford use the dual part numbers as described on these parts?
Re: Radiator Hose Marking -
« Reply #1 on: June 22, 2013, 12:56:34 AM »
Some, but not all had the extra service number stamping.  No clue if this was something that Ford required from the supplier.
Offline sanluis09
« Reply #2 on: April 04, 2016, 05:55:47 PM »
Hi,
I was reading this topic and come up with a doubt. Talking about part number C4ZE-8260-A, I've seen several examples (original and repro) that have an A-Y marking right next to FoMoCo logo. I know that AY is the vendor code, in this case Firestone. But there are others (AU for Goodyear, etc).
But, what about 4V markings? I've seen a lot of examples that instead of A-Y, had 4V next to the FoMoCo logo. What does 4V stands for? Is it for type of engine (289 4V) ? If so, does it means that a 289 2V car must not have that specific stamped hose? So, what should a 289 2V have?
Regards,
sanluis09
« Last Edit: April 04, 2016, 06:02:43 PM by sanluis09 »
1965 WW Hardtop, 289-2V, 3-speed manual transmission. Unrestored. Assembled in Mexico on the time frame of: Oct 64-Feb 65.
