Author Topic: More 64 1/2 carpet questions  (Read 1218 times)
Offline Dave Stribling
« on: June 21, 2013, 10:18:23 AM »
1. Code 42 white with blue accents. Carpet is blue, sides are white. Does the vinyl match the carpet color or the interior primary color.  Did a search and got two different answers.
2. Where the blazes do the ten screws in the AMK bag go? I can only see the four on the front of the seat platforms.
Thanks - Dave
Re: More 64 1/2 carpet questions
« Reply #1 on: June 21, 2013, 04:16:37 PM »
Dave,
  The carpet is supposed to use 8 screws without a console, 6 with. I've seen early 65 Dearborn Hardtops with 4 so it may be an assembly line decision (done by a guy on the line?). The 10 pack is AMK packaging.
« Reply #2 on: June 21, 2013, 04:34:37 PM »
The vinyl glued to the inner rockers should match the primary color of the interior, which in this case would be white.
« Reply #3 on: June 21, 2013, 05:12:41 PM »
You ruined my Day Charles. Two other MCA judges said blue. Thanks guys :)
« Reply #4 on: June 21, 2013, 07:48:12 PM »
It's actually in the MCA rulebook, so shame on the MCA judges for giving out wrong info!   :P
G. Carpet: Original molded type correct color for interior. 64½ - no toe pad. 64½-early 65 - (except convertible) must have serge edges except at firewall and vinyl strip from floor pan to scuff plate. Vinyl strip is color-keyed to kick panel. No dimmer switch grommet in carpet. Convertibles may have rubber pad on dimmer switch. Carpet on top of firewall pad ........................................... 5
Workmanship, condition and cleanliness .......................................................................................... 6
« Reply #5 on: June 22, 2013, 12:44:37 AM »
Couple of original examples to illustrate Charles comments/observations
