Author Topic: 390 Bellhousings for 4 Speed  (Read 1840 times)
Offline 69GTconvert
« on: June 13, 2013, 11:19:07 AM »
I am still searching and collecting 4 speed toploader parts and am not sure which bellhousing I should be looking for. From the research I have done, it appears I should use either a C6OA-6394-D or C9AA-6394-C bellhousing. Can anyone tell me which bellhousing would be correct for my Mustang? It's a 390, Dearborn built on April 8 and is a close ratio.
Thanks.
George
Georgia
1969 Mustang GT Convertible
390 4V, Close Ratio 4 Speed
Royal Maroon - Black Standard Interior w/ High Back Seats
Re: 390 Bellhousings for 4 Speed
« Reply #1 on: June 13, 2013, 09:50:06 PM »
My book only goes up to 1968, but says that the C6 variant you list was for before 2/15/68.
Offline 70cj428
« Reply #2 on: June 14, 2013, 11:56:43 PM »
Just FYI, I've taken apart at least a dozen 69/70 big block 4 speed cars, and they all had the C6OA-D bell housing ("Z" bellhousing) and they can be found dated at least thru 1970, so I'm fairly certain that that's the right bell housing for your car (99.9999% sure)   ;D    I think the C9AA-C bellhousing is for full size cars like a galaxie and has a boss and threaded hole to mount the Z bar pivot. Your car has a bracket that bolts on using the bellhousing bolts for the inner Z bar pivot. The "Z" bellhousing is fairly common but expensive as it's used on mustangs and fairlanes and is really popular, you can expect to pay 250.00 to 500.00 for the bell, block plate, and lower cover. The full size bell (C9AA-C) is a lot rarer but less in demand as there are not a lot of 4 speed 69 galaxies getting restored...
BTW, when you go to buy a bell, look it over carefully, as they tend to break around the block dowel pins, also pre 1968 bells use a pivot without a slot for the fork retainer, if you buy an earlier bell, you can either change the pivot (the newer style is repopped) but you'll see that from the outside unless you have the rivits made and are really good at riveting, or use an older fork...
Hope this helps, John
« Last Edit: June 15, 2013, 12:05:22 AM by 70cj428 »
Offline 69GTconvert
« Reply #3 on: June 15, 2013, 07:24:25 AM »
Thanks Randy and John for all your help. Now I know which bell housing I need to buy. Just have to find one.
George
Georgia
