Author Topic: 1968 upper radiator bracket differences  (Read 2337 times)
« on: June 05, 2013, 06:26:35 PM »
Pulling some parts for a customer today and noticed that there are at least 3 variations on the 24 inch upper radiator brackets found on 1968 cars. These brackets all came from Cougars, so they would only be from Dearborn and San Jose factories. Did a search, and nothing came up. As shown in the photos, the difference is in the ends where the rubber insulators are located.
Re: 1968 upper radiator bracket differences
« Reply #1 on: June 05, 2013, 07:29:18 PM »
There is at least one TSB concerning a redesign of the bracket, if I recall correctly - where it rubbed the top tank. Will try and find time to did it out with its illustrations and text (busy couple of weeks coming up)
Offline TLea
« Reply #2 on: June 06, 2013, 08:39:39 AM »
My guess would be it had to do with the lack of clamping ability with was finally combatted in 69 by the goofy looking extra lag screw through the top
Offline Murf
« Reply #3 on: June 06, 2013, 08:58:41 PM »
Our 68 - schedules build date of 03 April, SJ plant-  has the clamp that matches the bottom one in your image.
John Murphy
« Reply #4 on: June 09, 2013, 07:44:39 PM »
The bottom picture is the last design I believe and what was last serviced. Had a few NOS ones over the years. The repros have the that same flaired edge just more so then the original it seems. Not knowing any differeance the repros are typically copied from the last serviced design.
« Reply #5 on: June 09, 2013, 07:46:43 PM »
The middle one is typicall of 67 production.
« Reply #6 on: June 10, 2013, 12:29:58 AM »
Found the TSB article #1319
Text basically warns of potential Upper Radiator tank damage (AC or extra cooling units) due to retain bracket digging in to radiator at rear tip of brackets.
Fixed in production after Nov 1967
« Last Edit: July 02, 2020, 05:59:06 PM by J_Speegle »
