I need help getting my door handle installed. I had the door panels replaced and the upholstery shop couldn't get the door handle back on. This is the early clip style, not the kind that screws on. The problem is, when the clip is on and the door handle in place, there is no room to get the clip pushed forward and over the shaft of the latch assembly, the door panel is just too thick. If the clip is pushed all the way in on the back side of the handle, I can't get it to go all the way on the shaft and into the circular groove that is on the latch assembly shaft in the door.
Any ideas? The unique tool for removing the clip can't get behind the handle to push the clip on, so I'm guessing thee is some other technique?
