Author Topic: door glass removal  (Read 1293 times)
Offline kcodecoupe
door glass removal
« on: June 03, 2013, 02:33:24 PM »
what is the best way to remove & install door glass  from the crimped metal channel due to a rust, thanks.  chuck.
Re: door glass removal
« Reply #1 on: June 03, 2013, 02:58:00 PM »
Take the 2 screws off the back where the stainless trim attaches, then use a block of wood and rubber hammer to knock the bottom track off.
Offline kcodecoupe
« Reply #2 on: June 03, 2013, 08:57:30 PM »
Thank you Charles, is there a need to apply any adhesive to the glass when you tap it back in with the rubber hammer,  chuck.
« Reply #3 on: June 03, 2013, 09:00:06 PM »
no adhesive used there. use glass setting tape instead. npd carries it. also may be available to you locally at a glass shop.
« Reply #4 on: June 03, 2013, 11:53:51 PM »
Yes, definitely use some new glass setting tape as Fred recommended.  Keep in mind that there are different sizes of setting tape.  You should be able to measure the original to get an idea of what you need.
Offline kcodecoupe
« Reply #5 on: June 04, 2013, 07:19:46 AM »
Thanks for the info guys . Chuck.
