Author Topic: FB Coat hook location  (Read 2733 times)
Offline MWM
« on: June 01, 2013, 08:16:36 PM »
Silly question. But.  Where are the coat hooks located on a '65 SJ fastback? I have the head liner out, but found no reference in the interior assembly manual.
Thanks!
Re: FB Coat hook location
« Reply #1 on: June 01, 2013, 08:28:02 PM »
The Fastback coat hook installation is documented in the Body Manual, AM0011 page 51.
Offline MWM
« Reply #2 on: June 01, 2013, 08:35:49 PM »
Well that explains it. That is the one manual that I do not have - yet!
 Thanks Jim, I'll go and search for the manual. Although I'll probably have a problem finding any holes as the body shop sealed most of those up.....
« Last Edit: June 01, 2013, 09:39:22 PM by MWM »
Offline C5ZZ
« Reply #3 on: June 01, 2013, 11:48:53 PM »
Don't believe that they put coat hooks in on 65 fastbacks
but did in 66. Don't have them in mine.
MCA # 00945
Rangoon Red/Red Interior
« Reply #4 on: June 02, 2013, 12:41:32 AM »
I have coat hooks in my May 65 San Jose GT Fastback.
« Reply #5 on: June 02, 2013, 12:55:16 AM »
Ooops, the 65 reference is AM0006 page 55. I got both 65 and 66 books on my desk open for some research.
« Reply #6 on: June 02, 2013, 12:11:45 PM »
On my car the coat hook screw center is 2 &1/4" forward of the sail panel and 1 &1/8" up from the windlace.  Should get you into the right area ?  Brian
Offline MWM
« Reply #7 on: June 02, 2013, 06:34:32 PM »
Thank you Brian!
I did go back and found what may have been a hole close to location you described, but it was welded over.  So... I work it out
« Reply #8 on: June 02, 2013, 06:42:26 PM »
Sorry I missed this earlier - as mentioned early Fastbacks didn't have the coat hooks while later ones did ;)
Offline C5ZZ
« Reply #9 on: June 03, 2013, 09:45:53 PM »
Thanks Jeff,
I have a Oct 64 Dearborn fastback which would be considered early and don't have coat hooks,
what month in the 65 model year did they start putting coat hooks in?
MCA # 00945
« Reply #10 on: June 03, 2013, 10:37:06 PM »
Thanks Jeff,
Just checking so I can answer as best possible - which plant?
Don't have allot of pictures  of that area on 65's -so not allot of data points but will look through the collection as at least try to provide a rough range.
« Reply #11 on: June 03, 2013, 11:54:35 PM »
The Jan '65 Dearborn K code fastback I had didn't have coat-hooks, no holes for them either.
