Author Topic: 1967 Gt 390 air cleaner filter size & or part number  (Read 2483 times)
Offline 67BB390
« on: May 31, 2013, 03:43:44 PM »
The only filter I can find doesn't let the lid sit down all the way & my father in-law lives next to an old guy that has a massive stash of vintage filters so I was going to see if he had any.
« Last Edit: August 10, 2022, 05:00:51 PM by J_Speegle »
Re: 1967 Gt air cleaner filter size & or part number
« Reply #1 on: May 31, 2013, 05:28:45 PM »
Same filter as used on the Boss 302 and the 428 CJ cars (later years) I believe
The filter books always have the wrong number though the diameter is normally correct.  Will see if my Cougar has a part number on the filter (had the same problem there ) and will provide that number for you to try.
Offline 67BB390
« Reply #2 on: May 31, 2013, 08:19:16 PM »
Hey Jeff, I got the new GT air cleaner from Drake & the snokle filter is too tall, Thanks much.
« Reply #3 on: May 31, 2013, 11:06:09 PM »
Have 4-5 in my other garage so I can test fit ;) once I get a number - hope the repo is the same
« Reply #4 on: June 01, 2013, 06:27:17 PM »
Reporting back and has been my experience in the past a visit to the local parts store produced an "official" part number and a filter that was approx too tall by 1". That one is labeled CA114 for Fram. Somethings just don't change :( Guess they are just using the Fairlane filter as a one size fits all though that air cleaner is taller.
What I found
Mr Gasket makes a filter that does fit the application (more expensive than the cheap Frams, Wix, ....) Its a little larger dia (by maybe 1/4") but with the lid on no movement (seals) in the filter
Ford older books list the correct filter size as 13.3" OD - 11.32" ID - 2.22" high
Closest Fram I could find was CA 340A with 12.66" OD - 11.19" - 2.5" high
Offline nham3407
« Reply #5 on: June 03, 2013, 10:37:00 AM »
I have experienced the same difficulties with my air cleaner lid and any filters I can locate.  Jeff, do you have the part number on the Mr. Gasket filter handy?  If not, I will just utilize the dimensions you provided for the next closest.  Thank you
67 GT S-Code, San Jose, 06/67
72 Mach 1, Dearborn, 01/72
Offline 67BB390
« Reply #6 on: June 03, 2013, 01:54:02 PM »
13.30OD and 2.22 high, would be an FA-41, or our part number 9601-9 or a - FA-612R will work also. Did some digging at NPD or other if it helps
« Reply #7 on: June 03, 2013, 02:21:26 PM »
Napa Gold filter #2063  is 2.193 inches tall. That is what we sell.
« Reply #8 on: June 03, 2013, 06:34:45 PM »
Believe its 1480A  - Looks like others have come to the rescue also ;)
