Author Topic: 66 Metuchen Rocker Moulding Clips  (Read 1003 times)
Offline bryancobb
  • Silver Level Subscriber
  • 2009 Ridn' Around
« on: May 29, 2013, 01:03:46 PM »
Were the clips for the rocker mouldings green zinc-chromate primer?  Mine appear OEM and are green.
Also how were they attached on the assembly-line?  Pop-Rivets?
66 Metuch Conv
Nightmist, Std Blu Int
Re: 66 Metuchen Rocker Moulding Clips
« Reply #1 on: May 29, 2013, 02:14:26 PM »
All the originals I have seen, regardless of assembly plant were olive green color.  Yes, pop rivets to attach.
Offline bryancobb
  • 2009 Ridn' Around
« Reply #2 on: May 29, 2013, 02:36:44 PM »
Thanks Charles.
66 Metuch Conv
Offline C5ZZ
« Reply #3 on: May 29, 2013, 06:25:40 PM »
All of the clips I have seen are the green color as mentioned.
The only difference I have noticed is that some have about
a 3/8" hole in the very center of the clip and some don't.
Have you also noticed that for the pop rivit holes one is slotted
and the other is a hole, believe the slot goes to the bottom or
it may not make a difference.
MCA # 00945
Rangoon Red/Red Interior
« Reply #4 on: May 29, 2013, 06:42:26 PM »
Yes, normally slot goes down.  Attach the top rivet first.
