Author Topic: Door Seal, inside lower C7WB-6520272-3  (Read 1921 times)
Offline Angela
« on: May 28, 2013, 04:22:47 PM »
In the assembly diagrams there is a lower inside seal shown, PN C7WB-6520272-3, attached to the bottom of the door with six phosphate screws. There is a note specifying it is only used when "R.P.O. moulding floor side member is not installed". What does that mean? What does "R.P.O" stand for? I suspect Rocker Panel comes into play here...
Re: Door Seal, inside lower C7WB-6520272-3
« Reply #1 on: May 28, 2013, 04:51:29 PM »
RPO is Regular Production Option
Basically, something that is checked off on the dealer order sheet.
Offline Angela
« Reply #2 on: May 29, 2013, 09:57:57 AM »
Regular production option...... hmmmm, interesting. Thanks! That's neat to know.
So in this case, does the "RPO" refer to the rocker panel / sill plate molding? In other words, was there an option that deleted that aluminum molding and when that was the case they installed this additional door seal? I don't understand why the lack of the molding would require an additional door seal. Perhaps I'm running down the wrong rabbit hole....
« Reply #3 on: May 29, 2013, 11:15:26 AM »
Have no idea on this.  Probably an example of why the assembly manuals should be used with caution, but I'm sure there is probably an explanation.  I don't have a copy of the manuals for '67.  Maybe someone can post up a pic of that page?
« Reply #4 on: May 29, 2013, 06:56:39 PM »
The seal sounds like the lower seal used for a short period in 69. Never seen one or holes for one on a 67-8 door.
Maybe another mistake in the assembly manuals - not the first :(
Offline Angela
« Reply #5 on: May 30, 2013, 10:40:17 AM »
Jeff, this particular '67 car DOES have the holes drilled at the bottom of the door, as described in the 67 assembly diagram. I can certainly post a picture if you're interested.
« Reply #6 on: May 30, 2013, 05:26:15 PM »
There's an NOS pair of these currently on ebay.  Search by the part number.
« Reply #7 on: May 30, 2013, 08:52:54 PM »
Yes and please remind us of when and where it was built.
Offline Angela
« Reply #8 on: May 31, 2013, 12:19:23 PM »
SanJose, June 30, 1967
