Author Topic: 1966 200 six Carbs  (Read 8060 times)
Offline koski19
1966 200 six Carbs
« on: May 13, 2013, 12:24:09 PM »
1966 200 six
The carb on this engine is a Holley 1V. Did Ford use Holley, Carter and Autolite carbs on these engines or just the Autolite 1100?
The numbers on the Holley carb seem to me to be Ford numbers. Here they are:
On the side near the accel pump #6R3685B
                                                            A-6
On the accel pump # 34R-5008B
On the linkage side #4694-2
                                    9796
If this is the original carb, I'd like to have it rebuilt. Anyone have a link for a rebuilder?
Also, where did Ford put the casting numbers/ID numbers on the hood? The hood I'm working with may be a
reproduction since I can't seem to find any numbering on it.
Jeff
« Last Edit: May 18, 2020, 05:11:14 PM by J_Speegle »
Re: Carbs
« Reply #1 on: May 13, 2013, 03:16:09 PM »
the only #'s on the hood are the date codes. you should have an autolite 1100 carb on the six. try here for rebuilder. http://www.carbontooters.com
Re: Carbs
« Reply #2 on: May 13, 2013, 04:45:20 PM »
Don't believe any early 6 cylinder Mustangs used a Holley -  just Autolite's as mentioned
Offline koski19
Re: Carbs
« Reply #3 on: May 13, 2013, 10:18:06 PM »
Thanks for the info guys.......I'll be looking for an 1100.....
Jeff
Offline koski19
Re: Carbs
« Reply #4 on: May 13, 2013, 10:18:47 PM »
Clicked on the link and it was no good......Jeff
Re: Carbs
« Reply #5 on: May 13, 2013, 10:28:12 PM »
Offline koski19
Re: Carbs
« Reply #6 on: May 14, 2013, 05:23:34 PM »
try this instead....  http://mysite.verizon.net/vze2gsgu/index.html
That worked!...I'll place in favorites......Jeff
Offline Carbontooters1
Re: Carbs
« Reply #7 on: May 15, 2013, 01:00:35 PM »
For the years of 1963-1969 Ford used the Autolite 1100 only. They did use a Holley 1940 as a replacement in 1970. 1968 and 69 are different from the 63-67 1100 due to the change of the distributor. Both series of carbs work well, but the 1940 does not get very good fuel economy in comparison to the 1100. Hope this helps!
Re: Carbs
« Reply #8 on: May 15, 2013, 01:09:37 PM »
Thanks for the confirmation  didn't think the Holleys were used originally ;)
« Last Edit: May 15, 2013, 01:14:14 PM by J_Speegle »
Offline C5ZZ
Re: Carbs
« Reply #9 on: May 15, 2013, 10:36:14 PM »
Jeff
Do you have a automatic or manual trans?
There were two different 1100's used on the 66 200
M/T used a single diaphram
A/T used dual diaphram
Here is a picture of the A/T version with the SCV
MCA # 00945
Rangoon Red/Red Interior
Re: Carbs
« Reply #10 on: May 15, 2013, 11:39:03 PM »
There were two different 1100's used on the 66 200..........
And four different numbers depending on trans and if it came with Thermactor ;)
Offline koski19
Re: Carbs
« Reply #11 on: May 16, 2013, 10:51:24 AM »
Today, I found the following for the Holley 1V carb. According to the reference book Mustang 1964.5 to 1973 Restoration Guide, Copyright  1998 Corcoran/Davis on page199 shows that the Holley Carb was used in 1965/1967 on the 200 six cylinder.
Year     CID     Type     ID                Part #
65/67   200     H-1       D0PF-K        D0PZ-9510-A
Since the designation 1965/1967 was used, does this mean that 1966 is not included?
There are quite a few listings for the Autolite, Holley and Carter for carbs used on the 200 six.
The reading of this chart shows that the 66 was listed separately and it shows 1966/1967 and 1966/1969.
I would then assume that the Holley I have is for a 1965/1967 200 six.
Jeff
Re: Carbs
« Reply #12 on: May 16, 2013, 11:10:30 AM »
look at those p/n's. they are for 1970. holley carb was used as a service replacement. you need the correct 1100.
Offline koski19
Re: Carbs
« Reply #13 on: May 16, 2013, 11:42:41 AM »
I have the C4 transmission..
Offline koski19
Re: Carbs
« Reply #14 on: May 16, 2013, 11:49:24 AM »
I agree...so why would they (authors) list them in the book as original or at least state they are service replacements?
jeff
