Author Topic: AC Bracket / Tag / J Clip  (Read 2645 times)
Offline ChrisV289
« on: February 08, 2010, 04:22:48 PM »
For a 65 SJ fastback:  Does anyone know the correct order this should be placed in or if the j clip should even be held on with the same bolt as the bracket that goes from the compressor to the back of the manifold?  I tired to put the j clip then the tag under bracket but it doesnt seem like that fits very well.  Anyone have a pic as to how it should go?  Also is the j clip for this the same exact clip that goes along the valve covers or is it slightly different?
2009 V6 Mustang Coupe
Re: AC Bracket / Tag / J Clip
« Reply #1 on: February 08, 2010, 08:54:15 PM »
Chris here is the  clearest picture I have to offer. It is the same orientation I see on most of the 66 SJ cars also (bottom picture)
5R08C182378
6R07C231374 - have most of the wires running inboard of the mounting bolt but this one is outboard -car is a 12K original mile car
Offline ChrisV289
« Reply #2 on: February 08, 2010, 09:16:51 PM »
Jeff,
That helps a little,  do you know what order it should be in?  Should the j clip be under or over the tag?  Also is this j clip the same as the ones on the valve cover?  NPD sells both but at different prices...When I put it on it looks like it should be longer to clear the bracket a little better...
Offline rockhouse66
« Reply #3 on: February 09, 2010, 12:45:15 PM »
Excuse me if this is a thread highjack, but my 9/65 SJ car has this A/C compressor, and the original owner says the car had A/C when he bought it.  No bolt on tag, just this riveted on one on the front.  What do you think?
'66 GT FB
Offline 5F09CNot4Sale
  • If it does not fit, you need a bigger hammer!
« Reply #4 on: February 09, 2010, 04:08:18 PM »
Rockhouse66, diffrent tag, that one would be faceing the firewall.
5F09C3031XX Sept 28 64 Dearborn
5F07F1838XX June 29 64 Dearborn
Offline rockhouse66
« Reply #5 on: February 09, 2010, 07:02:23 PM »
OK, so they all have both tags?  The one I posted and the bolt on one on the top?
'66 GT FB
« Reply #6 on: February 10, 2010, 11:08:56 AM »
Yes.  The compressor tag with rivets identifies the compressor.  The bolt-on tag just has service instructions for the amount of freon.
