Author Topic: 1970 Mach 1 Brake Booster Finish?  (Read 1432 times)
Offline razrbak
« on: May 10, 2013, 09:03:40 AM »
70 mach 1, Dearborn, 09/69 build.  Not sure if all of that matters, but what is the correct finish for the brake booster, semi-gloss black?  Thanks.
Re: 1970 Mach 1 Brake Booster Finish?
« Reply #1 on: May 10, 2013, 04:58:37 PM »
Semi-gloss black booster, valve, spacer and master cylinder with cap and bale painted as a unit is the current understanding.
Brake line connections had small plugs in each that would produce a round shadow when removed for installation
« Last Edit: May 10, 2013, 05:02:35 PM by J_Speegle »
Offline razrbak
« Reply #2 on: May 11, 2013, 12:27:55 AM »
Thanks Jeff!
