Author Topic: 289 Automatic Speedo Cable Clip  (Read 2441 times)
Offline PraireBronze
« on: May 05, 2013, 09:22:02 PM »
I have this clip that I bought for the speedo cable
Is this the right clip for my car?
Where exactly does it go?
How is it installed?  It looks like you jam a screwdriver in to spread it apart?
Anyone have a picture of it installed?
Thanks!
« Last Edit: May 18, 2020, 05:12:05 PM by J_Speegle »
- Tim -
1965 Prairie Bronze 2+2 (under construction)
Build Oct '64 San Jose
289 4V Automatic Transmission (A-code clone :P )
Black Std Interior
AC, PS, Style Steels, 1" Drop, Konis
Aluminized 2 1/4 Exhaust, Tri-Ys
Offline bryancobb
  • Silver Level Subscriber
  • 2009 Ridn' Around
Re: Speedo Cable Clip
« Reply #1 on: May 05, 2013, 09:38:53 PM »
Look close and you can see it in this pic.  I installed it just like you said but I could not get it to pull-up tight.  They probably had a special tool on the assembly line.
66 Metuch Conv
Nightmist, Std Blu Int
« Reply #2 on: May 06, 2013, 12:52:08 AM »
Thanks!
The "special" tool looks very close to a screwdriver that spreads the center of the "W" shaped locking clip down when the cable is in place and then installed into the appropriate hole. Don't use too big a hammer.
« Reply #3 on: May 06, 2013, 08:09:53 PM »
Thanks.  That helps a lot.
I just ran across this in the NPD catalog, and it says its for the speedo cable 65-66.
It looks really familiar, so I think I have or had one.  Where does it go?
- Tim -
Black Std Interior
« Reply #4 on: May 06, 2013, 09:01:37 PM »
That's for the fuel and brake lines located a bit further back in the picture of the undercarriage.
« Reply #5 on: May 07, 2013, 12:05:26 AM »
Ah yes.  I see it on my car now.  NPD lists that as a clip for the speedo cable  ::)
- Tim -
Black Std Interior
Online CharlesTurner
« Reply #6 on: May 07, 2013, 12:31:24 AM »
It also is correct for a 4sp speedo cable, where the cable comes up on the passenger side toe-panel.
Offline Brant
« Reply #7 on: May 12, 2013, 04:35:15 PM »
